Location for 2nd coolant temp sensor?
Old Aug 15, 2006 | 09:16 AM
JoeZ's Avatar
Default Location for 2nd coolant temp sensor?
I'm using the rear passenger side head for the sender to work with my stock gauge. I also want to run a VDO gauge, and was looking for a good place to put the sender. I've heard of people tapping the water pump, and some have found a plug on the side of the block (near starter). Are there any other locations, and what are the pros/cons of the 2 spots I mentioned above.
TIA!
Old Aug 15, 2006 | 11:33 AM
Brains's Avatar
What about the front of the drivers side head? The plug on the side of the block, I think you're referring to anyway, is where the 'vette has the OIL temp sender.
Old Aug 16, 2006 | 03:23 PM
72ChevelleConv.LS1's Avatar
any passage that has watter in it is ok for checking the temp of the coolent. I have heard of people taping the watter pump this will work ok.
