here is a LS1 retrofit schematic
Old Sep 20, 2006 | 06:05 AM
chrisp3's Avatar
ukv8, the 99 ls1 pdf file worked great for me.
Jhankinson, great job on the schematics. i had started on the 99-02 awhile back and never quite finished them.wish i had more "free time" like you do.
I'm thinking all of these schematics need to be moved into the sticky section...just so new guys ( like me ) can find them easier and use them.
chris p
Old Sep 20, 2006 | 11:24 AM
ukv8's Avatar
p
Yup worked great for me too after I updated my ye olde adobe reader
Old Sep 20, 2006 | 08:27 PM
pearceleather's Avatar
Wow that is great. That schematic is going to save tons of time. Thanks! Seems like you eliminate half of the original harness.
Old Nov 13, 2006 | 10:21 PM
wildmanaaron's Avatar
I am tired and confuse so don't think I'm an idiot for asking this, but what does the C220, C105, and such represent?
Also where is the computer plugs ins, the ones that plug into the ECM?
Old Nov 13, 2006 | 11:10 PM
Davy_Baby9's Avatar
This may be a stupid question but where the hell is the injector wires and coil wires?
Old Nov 14, 2006 | 08:43 AM
Hersker Hans's Avatar
om trying to write a pinout list on my 2004 gto LS1, ive found some badly scanned schematics im trying to work off, anyone seen any info on 2004 gto? i've got a book on it in the mail now.
Old Mar 1, 2007 | 07:30 AM
JxxxOxxxE's Avatar
I am wondering the same...? Am I just not seeing something?
Old Mar 1, 2007 | 08:07 AM
chrisp3's Avatar
The injector/coil wiring was not in the schematic simply because there is nothing different about it. It connects to the motor in the same manner as original. Basically, the schematic shows what wires/relays you will need to contend with for your swap.
ChrisP
Old Mar 2, 2007 | 12:37 AM
JxxxOxxxE's Avatar
ChrisP
ok, but for some reason, I thought that you had to have seperate power supplies to the injectors and coils...?
Old Mar 2, 2007 | 09:43 AM
chrisp3's Avatar
Well, yes you do, and the schematic shows that. But the schematic doesn't show the wiring to the coils/injectors because those wires are not changed.
Wiring on separate circuits(as in the schematic) provides you with the factory type wiring, meaning you will have a 'limp home' mode if something were to happen to one side of coils/injectors. You would 'limp home' on half of the engine.
But if you wanted you could tie them all together and when/if there's a porblem you would be limping home via tow truck.
Old Sep 20, 2008 | 09:29 AM
Jeff Smith's Avatar
Those links not works.....
Old Sep 20, 2008 | 09:07 PM
  #32
loweredd's Avatar
Which ones? I just tried the 98's, and they worked for me.....is your Adobe up to date?
Old Apr 21, 2009 | 10:39 PM
  #33
JRocket's Avatar
Thats good stuff right there!!!!!!!
Old Apr 22, 2009 | 09:08 AM
  #34
rockytopper's Avatar
Guys the schematicis for the 99-up are already in the FAQ conversion thread in the stickys. It has already been done I used it on my swap. This picture will also help but I believe I discovered that the 220 and 230 are labeled wrong, they are swapped. If someone can confirm this I will edit the photo and correct it for all to use.
Old Apr 22, 2009 | 08:46 PM
  #35
TS99SS147's Avatar
C100 pin A is hot in run and start IGN/INJ bank 1 15A
C101 pin B is hot in run and start IGN/INJ bank 2 15A
see this page for more info
http://www.dxsoftware.com/magnus/wiring.htm
Can someone explain how the A/C relay controlling C100 pins B(red 43 A/C clutch control) and pin C(red 18 A/C clutch status) relate to C230 pin F(red 17 A/C request signal)?
Old Mar 29, 2010 | 01:00 AM
  #36
ge_forcez22's Avatar
With a pinout like this, it should be easy to keep the stock 1998 Mustang cluster and have everything working... right?
-Garrett
Old Aug 30, 2012 | 03:43 PM
  #37
JSM's Avatar
JSM
Originally Posted by Jhankinson
before someone was asking if this could be done for a 1999 harness. Well I had some free time so i figured i would write one up. If anyone sees anything wrong with it...just let me know so i can correct it ASAP.
J-
-edit-
I tried to include everything in the harness...A/C and all so for those who want it will have it as well.
Has any confirmed the accuracy of this? I tired looking in the Conversion section and could not find the 99.
Old Sep 3, 2012 | 06:37 AM
  #38
1970 LSCamaro's Avatar
Thanks, this is awesome information
Old May 28, 2014 | 12:08 PM
  #39
oldgoat69's Avatar
I have a similar pinout guide for the E40 PCM to a 03-07 truck harness in Excel format if anyone needs it. Just PM and I will forward. This site wont accept the excel format.
