here is a LS1 retrofit schematic
now if i could just figure out where i'm going to mount the pcm and the relays. i'm thinking everything is going under the right side dash, just for the sake of keeping it out of sight.....hummmmm....any sugestions?
once again, thank you for your help!!
*EDIT-see post #5 for updated schematics.
chris p
disregard that first set of schematics, there were a couple of errors. the 'oil pressure light' is really a 'low oil level light' and the 'hot' and 'switched hot' that connect to the relays have also been changed. (i had them reversed)
thanks to G-BODY for pointing this out to me, and helping me correct it.
hope this isn't a problem.
chrisp3
I used my schematic to wire my car and i think it made things go a little easier seeing the big picture, so to speak. but, G-BODY has it posted in the faq section in a word document in written form, so there is really nothing stopping you.
all i did was make what he wrote in picture form. i'll try to do the 99+ tonight, depending on what my girlfriend has in store for me
just from glancing at what G-body wrote in the faq, it looks as if there is not that much of a difference. and since i still have the cad file of the 98 it shouldn't be hard at all to switch some things around.
chris p
Jan
chris p
Headlights, taillights, fuse pannel etc. tx
I believe you will need to keep your original body harness and fuse panel for the items you mentioned. Or, get you a new aftermarket one from Painless or another supplier. If you get a new one, get enough capacity (circuits and proper fuse sizes) to power all of your body circuits and the new PCM, fuel pump, fans, and any other accessories you will be adding. And get a few extras for future accessories you may want to add.
J-
-edit-
I tried to include everything in the harness...A/C and all so for those who want it will have it as well.
J-
-edit-
Great job, this will help many in the future. Thanks!
