The Next 240sx S13 With LS1
Old 10-31-2006, 09:22 AM
  #81
nani's Avatar
do you still have your stock diff and axles? any pics of the motor mounts?
great project BTW im looking for a ls1/t56 from a corvette around md for my 89 240sx
Old 10-31-2006, 02:53 PM
  #82
icantdrift's Avatar
now you need some baller *** wheels... like these
Old 10-31-2006, 03:03 PM
  #83
Chin180sx's Avatar
Yeah atleast! HAHA those the equip's have a problem clearing Z32 brakes. But im looking for 18 or 19 x 12 in the rear. Stock Diff with a Tomei LSD in it. Stock axles. Motor mount can be found on page 1 or 2. I will be making a kit for those who don't have the capability to make them.
Old 10-31-2006, 05:40 PM
  #84
icantdrift's Avatar
the ones i posted are 18x12 -20 rears. fronts are 18x10 -35.
Old 10-31-2006, 10:21 PM
  #85
nani's Avatar
please do... if i had a garage.... or a welder. only have driveway. i will be very interested in the KIT. let me know
Old 11-06-2006, 02:58 AM
  #86
mikespeed95's Avatar
ewww stock axles ewwwwwwwww
Old 11-06-2006, 02:06 PM
  #87
owen v8litew8's Avatar
Originally Posted by Kamin
******* awesome.
your next Kamin!!!!!!!!!!
you know you want to!
Old 11-06-2006, 04:05 PM
  #88
Chin180sx's Avatar
Paint should be done by this weekend. I got all the wiring finished in the car including a relocated battery box in the back. Runs alot better the idle sounds healthy now. After that its just putting back everything and drive it around.
Old 11-07-2006, 12:10 PM
  #89
Ted J's Avatar
Shock loading wise I'm not to sure about what the stock axles can take but there is a guy with a S14 whose's running a trans brake, doing 1.37 60' times and 9.22's in the 1/4 mile and he's running the stock rear end (welded spider gears) and stock axles. Now, how long he's able to do that I don't know but it lead me to believe that those axles are stronger than people lead them on to be. Some people talk about them like they will break like a pretzel. Now, launching hard with a 6 speed and shock loading it with a cluth drop, that will probably be a totally different story.
I'm planning on running the stock axles for a while with welded spider gears since I'll be on a stock motor and if they break or start becoming questionable I'll look into upgrading the axles.
Old 11-07-2006, 10:17 PM
  #90
icantdrift's Avatar
the only time i've heard of axle issues were hard launches on drag slicks.
Old 11-07-2006, 11:16 PM
  #91
Slo_240sx's Avatar
I never broke an axle but I was on **** tires.... Lets see what happens with some slicks!
Old 11-10-2006, 12:32 AM
  #92
ive seen a lot of people break stock axles drifting around 330+rwhp when you run real tires.
but welded r200 FTW.
Old 11-10-2006, 06:21 AM
  #93
Ted J's Avatar
What about a welded r200, don't know what FTW means?
Old 11-10-2006, 08:33 AM
  #94
datboibrad's Avatar
r200 is the stock 240sx diff and ftw is for the win lol.
Old 11-10-2006, 02:09 PM
  #95
Reject's Avatar
ok alil off topic but wow your camera is AWSOME! wha type is it?
and need more videos'!!
Old 11-10-2006, 03:16 PM
  #96
the.erinyes's Avatar
great progress! Great Job! The headers and paint look awesome. Keep the updates coming.
Old 11-10-2006, 03:32 PM
  #97
Chin180sx's Avatar
Thanks, Most of the pics were taken with a Nikon D50 with a 50mm 1.8F the other ones were taken with a rebel XT with just the kit 18-55 lens. I like to swich up using them sometimes.
Once i get all of the body put back on ill get pictures of the whole car up (just dont mind the wheels)
Old 11-20-2006, 05:05 PM
  #98
Ted J's Avatar
updates:
Finished the clutch system. (i will get the part numbers you need to run those 2 lines from summit) FYI the whole having to use wildwood clutch master was the biggest effin pain to date of this swap.
Did you ever get a chance to post up that info? I'm curious what master cylinder you went with?
Thanks!
Old 11-25-2006, 01:31 PM
  #99
Chin180sx's Avatar
http://video.ls1tech.com/video/6c3ba...8400c45944.htm
I don't have a good 3rd 4th or 5th I did get it in on the video (2nd and 3rd pull) And the tires were pretty much just spinning 75% throttle.
Old 11-25-2006, 02:05 PM
  #100
no tiresmoke no care
Quick Reply: The Next 240sx S13 With LS1
