CJ5 with LQ4 6.0-intermittent start problem
Thanks
By the way, how did your conversion turn out?
How's the Jag/LS1 project going?
Thanks
Thanks
Thanks
Any Ideas?
I haven't had much time to work on my LS1 Jag lately... I have been accumulating parts over the summer and am now trying to set aside some time to dig into it again.
I'm glad your install turned out well! Definitely post some pictures up! As far as the starting problem goes... I am not sure. Is this only on hot starts? Is it just cranking and not firing at all? My next suggestion would be to put it on an engine diagnostic computer and see if it's pulling any trouble codes... but I'm not sure how you'd go about that without the data port.
-Dave
Thanks
Thanks
Thanks
I am putting a 5.3 in my CJ-7 this week and am wondering whether the truck manifolds fit or not?
Thanks
I have a 2 1/2 inch suspension lift which seems to help with clearance. The only issue I had with driveshaft clearance was the oil level sensor on the side of the pan. I trimmed the aluminum piece sticking out and replaced the sensor with a drain plug. For the exhaust, the truck manifolds also dumped on the framerail so I used 2002 F-Body manifolds and they worked perfectly. I ended up fabbing exhaust flanges for the manifolds though. I actually wanted to used manifolds because in my experience they seem to be much more resistant to exhaust leaks than headers...and cheaper too. Let's faced it, a 325 horsepower 6.0 liter in a CJ5 doesn't really need to benefit from the few ponies I might gain from headers. I will probably put on a different oil pan, probably F-body or C6 LS2. The truck pan hangs a little too far down for my tastes and with the Jeep almost any pan will work...probably even the winged one. My combo is 6.0/T18 four speed/Dana 20/4.10s/33s
Fastkat-One of the pics I sent you shows the drivers side exhaust manifold, can you post it-I don't know how.
Power on-did you do your harness or someone else-John Speartech did mine. I didn't have to do anything with grounds through the relay, just connect the labeled wires from John. I'm waiting to have the no start happen again so I can check for spark as I have a sneaky suspision I might be dealing with a suspect crank position sensor.
Truth is my swap went pretty smooth all things considered. Exhaust flanges was probably the most frustrating part for me. Even that wasn't that bad. $30 to the metal shop to cut them on a water jet and a couple of 12 packs to a friend at a machine shop to drill and tap holes.
Good luck
Aaron
The conversion looks great! How does that 6.0L run? It sounded great in the van but I never had a chance to take it out to see how it pulled.
Here's the pic...
Also, email me your email address. I tried to reply to your email and it didn't work.
-Dave
My home address is hackman@frws.com
Daytime number is 719-365-1564
Thanks
I have a 2 1/2 inch suspension lift which seems to help with clearance. The only issue I had with drive shaft clearance was the oil level sensor on the side of the pan. I trimmed the aluminum piece sticking out and replaced the sensor with a drain plug. For the exhaust, the truck manifolds also dumped on the framerail so I used 2002 F-Body manifolds and they worked perfectly. I ended up fabbing exhaust flanges for the manifolds though. I actually wanted to used manifolds because in my experience they seem to be much more resistant to exhaust leaks than headers...and cheaper too. Let's faced it, a 325 horsepower 6.0 liter in a CJ5 doesn't really need to benefit from the few ponies I might gain from headers. I will probably put on a different oil pan, probably F-body or C6 LS2. The truck pan hangs a little too far down for my tastes and with the Jeep almost any pan will work...probably even the winged one. My combo is 6.0/T18 four speed/Dana 20/4.10s/33s
Good luck
Aaron
Thanks
