CJ5 with LQ4 6.0-intermittent start problem
Not so sure it is my fuel pump now. Just happened again andI could hear the pump pressure up with no start. No tools with me, so I could not do much. Finally started like normal after trying several times.
Any Ideas?
Try turning the key on and off and allow the pump to run the priming cycle a couple of times and see if that works. Acehaag-I was thinking about the prime issue. I'll try that next time it does it. I'm also prepared to check for spark, in case it is crank position sensor
Dave, any chance you could post the other pics I sent you?
Thanks
