mount plates for '68 Camaro
A note to anyone who really wants to run the Hooker plates: it's not possible to get the engine far enough back to drop it down on the stands while a non-AC small-block heater core and/or wiper motor are still installed. Remove both before starting or you'll be replacing them... fortunately I was planning to eventually do a Vintage Air system and replace the wiper motor, so no huge loss to me (and not like I drive this car in the rain anyway).
rodder,
save your money and make your own. all you really need is a piece of 1/4'' steel and a drill. the mounts can be made really simple or quite complex. there are a few templets on the web. here is a templete that i got off the web and then gave it my own touch(added some curves and text). it works very well and the motor sits about 1.5'' from the firewall. should be about the same as the s&p mounts. i cut mine on my cnc plasma table and i will post pics of them soon,( mounted in the car currently!! )
chrisp3
mounts,oil pan and Hooker headers everything fit good. Had to dent the drivers
side tube slightly and grind about 3/16th off the pitman arm
. Already modified to work with Energy Suspensions mounts too! (don't think Jegs will take 'em back...)Chrisp: If I still had a vertical mill I'd probably do it. Sawzall and a hand drill are too much of headache for something that needs to actually fit.
topless69: where'd you have to grind on the pitman arm and which arm are you using? I'm using a 5-3/8 arm (new one from Rick's, same length as my original one) instead of the 5-7/8 Moog arm.
68LS1WANNABE: I not sure smoothing the firewall would make much difference unless you cut the whole thing out and moved it back. It's tight on both sides, not just the heater core area.
Whistler: mine fit OK other than firewall clearance. Mine look like they were hand cut/ground, so wouldn't surprise me if there was a lot of variance. Not the first time I've been screwed by Hooker... last time was headers for a '91 GMC C2500 pickup, the collectors were exactly in the middle of where the trans crossmember should be so I had to fab a new trans crossmember for it (not a big deal at the time since I was doing major frame mods to fit 13" diameter x 6ft CNG tanks under it). I'll learn my lesson eventually.
Tyler
Edit:
I Have an idea why they don't fit into the chassis, but I'll give Kurt at Autocraft a chance to answer questions about his engine plates.
I can see the motor mount (the gold lip) hitting the frame stand in your picture.
As for the motor mounts, the suggestions here are completely right. I ended up grinding a little off my plates and having to grand the tab off the motor mount itself that you're speaking of. Once I did the little bit of grinding, it fit like a glove. For some reason, your pictures look like the motor is sitting too high in the engine compartment. I couldn't fit my stock alternator brackets because the alternator was sitting on the crossmember, is your alternator holding your motor from sitting all the way down? As you can see I ended up making my own bracket and moving the power steering pump to make the accessories fit.
