1972 Camaro LS1 conversion Questions
X-Pauliber, those are the ones I was thinking of using. This is a dumb question but with those plates do you have to move the location of your old mounts on the frame? Or is it a direct bolt in? Also if there are any pontiac guys watching this one did you switch to the chev mounts and location? I assume that is what I will need to do.
You would need to swap to Chevy mounts in order to use the plates. Noone makes them so you'd need to go pull the mounts off of a Camaro subframe. I made my own. and welder them right to the frame and used the stock LS1 clamshell mounts.
http://www.geocities.com/thelastcaboose2/Page2.htm
Scroll down to "more custom modifications"
This isnt my car, mines a real piece compared (hahahaha) and I didnt wnat to bother with bolting the frame mounts down so I just welded them in place. I dont ever for see the subframe going back to an older engine (and who cares, theres a big notch for the A/C compressor anyway, not to mention the extreme firewall cowl damage from installing the 4th gen HVAC) so the welding didnt bother me. Just set the engine and tranny where you want it, make sure the driveline angles are correct (we'll see how good I am when I hit the freeway) and mock it up with soem cardboard cutouts. All said, it probabaly would have been easier just going with the adpater mounts, but it was raining her ein the bay area when I made the mounts and I didnt feel like lying in the mud in a junkyard pulling them. Ive also heard of clearance problems when using the mounts and the low mount compressor.
Yes the pedestals need to be unbolted and moved on the subframe. I had clearance issues with the oil pan and the back of the engine cradle. I unbolted the pedestals, bolted them to the engine, then set the engine and tranny into place where I wanted them. Made sure that the engine was square in the engine bay, checked the tailshaft angle and then tackwelded them in place. Pulled the engine out and welded them fast. Same thinking as above, that I don't ever see anything other than an LS motor in my car so I didn't bother drilling and rebolting them down.
Make sure to keep all your emmisions equipment from the wrecked car. It should pass without issues.
Andrew
Andrew
Well, there IS emissions on a 75 and older vehicle, technically. Just because you don't have to get smogged every two years does not mean you can do whatever you want. If you end up with a butthead cop who does a smog check on you on the side of the road and sends you to the ref, your screwed with the LS1.
That said, my LS1 is emissions free. LOL
I wish it was that way. Its not. The law says you must retain all emissions, your just exempt from biannual inspections. Thats all it says. They could change the law tomorrow and require everyone to smog back to 1966, as they've been trying the past few years. They've repealed emissions laws before, and they will do it again if they believe it will help them meet clean air goals. What a perfect way to get all the old vehicles of fthe road (like they want) give them time to mod all the old cars, pop the laws back in place, noone can smog, cars get crushed. Vehicles prior to 1966 didn't have any emissons equipment whatsoever (basically) and are therefore completely exempt. You still have to obey federal law which states you must retain all emissions equipment, as well.
If your pulle dover by a CHP officer, and he decided he wants to give you a roadside inspection, he can do that. Odds are he won't bother, but he can.
#32
#35
when i first bought my car it was a rolling POS and i got pulled over and a CHP officer had me pop my hood. I punked his *** and he got on his bike and left with no comment! I was pissed.
#36
Originally Posted by SICMARO
those are alll good stops, but not good enough to justify a vehicle inspection.
Judging by your avatar, I don't know if your an officer or not, but those reasons listed are in the San Diego training videos, and have been used in the Sacramento area, as well, as probable cause for illegal engine modifications.
![Gay!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_rainbow.gif)
