Painless Harness vs Speartech
Old Sep 3, 2006 | 12:05 AM
69c4x11's Avatar
Default Painless Harness vs Speartech
Could anyone rate the two harnesses ?? Has anyone installed the two to know the comparison ?? Plus Tech HELP ???
Old Sep 3, 2006 | 06:52 AM
Jones'n's Avatar
Well, I haven't used Speartech's harness, but I know tech help at Painless is not without extreme pain. You call and get some jackass with a flowchart telling you what they think is next vs. a real person with experience who knows what they are talking about.
Old Sep 3, 2006 | 08:15 AM
JoeZ's Avatar
Speartech customer service is TOP notch! John answered questions for me well before I purchased anything, then after I had received the harness he was more than willing to assist with any questions I had. Never wait more than a day for a response via email (many times response was immediate), always returns a phone call, never annoyed with a question even though I'm sure he's heard it a million times.
Check out this thread which has a few pics of my harness https://ls1tech.com/forums/conversions-swaps/555491-got-my-speartech-harness.html
Old Sep 3, 2006 | 10:11 AM
Stu Cool's Avatar
I'll pile on here with a vote for Speartech. I don't have any experience with Painless. I have one of his custom harnesses. I think "custom" is the keyword here. My harness was made specifically for my car, everything I needed and nothing more, custom adjustments in length to my specs. Everything labelled and fit exactly right. John's tech support is also the best, I did most of mine via email and when I had questions or ran into issues due to my own ignorance, his response was quick, patient and usually right on the money. I think the key difference is with Speartech you are dealing with the guy who realy knows his stuff, designs and builds it. With Painless the guys you get when you call are providing canned answers based on a trouble shooting chart. They have to be able answer questions on all of the Painless products so there is know way they can have the knowledge that John does. Painless makes excellent products, no doubt or they would not be as succesful as they are, but for our type of application, I think Speartech is the way to go. If I do another EFI project, he is the only place I'll go.
my $.02
Pat
Old Sep 3, 2006 | 12:21 PM
glock73110's Avatar
I have a painless harness,nothing special works though I was lucky enough to get ahold of someone who knew something the one time I called it was clearly marked no complaints
Old Sep 3, 2006 | 12:24 PM
SilverBullet73's Avatar
My vote is for Speartech also. I had a painless harness on my LT1 Monte. It was more like a "generic" harness. Didn't have wires to control the fans, aldl connector was not the correct year. Little things but they were a pain. They do label their stuff too, but I would still go with Speartech. John's tech support is excellent. He will help you out with any questions you have, very knowledgeable.
Old Sep 3, 2006 | 02:26 PM
jim57's Avatar
Default Can't compare only recommend.
I got my harness from John at Speartech. It arrived with the box destroyed by UPS. John took it back and checked it out, I believe he even put it on an engine to make sure it ran out O.K. Can't beat service like that.
Jim
Old Sep 5, 2006 | 10:05 AM
tuske427's Avatar
Actually, I have them both. I have a Painless set up for my Belvedere and used Speartech in my trans Am.
I got the Painless one first, having traded it for parts. the LS1 engine I have for that car did not include a harness, so a complete, new in the box deal sounded good to me.
Whereas my Trans Am engine had the factory harness, so I opted for Speartech to modify it and make it stand alone. It seemed to be more economical while achieving the same result.
The above posts are pretty spot on. John has been super friendly and helpful in answering questions, even after I made my purchase. Everything was labeled so it probably as easy as it will ever get for installing.
Same for the painless harness. Everything is labeled, the instruction book is clear and easy to understand. It includes part numbers, etc, too.
The differences I've noted are the following:
1- Painless requires the use of a '98 computer, so it makes it a little harder to track down specifically. And you may still need it reprogrammed
2- The Painless set up has a vats bypass module. the speartech doesn't. one more part under the hood and to be wired up, etc....
3- the Painless wiring seems to have longer wires- allowing you a little more freedom to locate the PCM where you want, etc. Not that this is any fault of Speartech, as it's the factory harness. It just works out this way.
4- Speartech included the fuel pump relay. I have to go buy one for my Painless wiring.
otherwise it's pretty similiar. I don't think you'll go wrong with either one.
I hope this is helpful.
Old Sep 5, 2006 | 01:32 PM
John B's Avatar
Moderator
It's all been said...I've had two of John's harnesses and they are 2nd to none. More importantly, if you ever have a question, he's right there with an immediate response! Don't forget about the Customer Service when evaluating products!
Old Sep 5, 2006 | 11:06 PM
G-Body's Avatar
sawzall wielding director
You can also have the VATS deleted so that you don`t have to wire up more stuff.
Old Sep 5, 2006 | 11:31 PM
Chin180sx's Avatar
Mike Peters (Mikespeed95) had a painless harness and he opted to use his stock harness. He said he didnt like the painful harness. and it never worked right for him.
Old Sep 6, 2006 | 05:26 PM
69LS1SixSpeed's Avatar
Default Speartech....
Without a doubt, I would recommend Speartech! John's customer service is the best I've seen for a somewhat complicated product. As stated before in this thread, he answers all questions in a very timely manner and put up with some of my "dumb" questions and didn't even flinch! For my money and performance there isn't even a close second place to consider!
Chuck
Old Sep 8, 2006 | 05:29 AM
topless 69's Avatar
I vote for Speartech have one for my LS2, very clean and only has what I want
on it. My friend has the painless-lot of unused wires and he had to use a 98 ecm
with it.
