Ls7 swap in 1971 Camaro
1- should I retain the dry sump oiling system and if so will the pan clear my subframe etc. I assume it's pretty shallow??
2-dbw or switch to a cable
3-can I use the Kooks headers from my 99 SS in my 71 Camaro. I've read that Pacesetters are an option.
4-who makes a bellhousing to adapt my TKO 500 to this engine with my original clutch linkage if possible.
I know I'm a pain in the butt I just need to get going on this and any help/answers are greatly appreciated
Thanks shupe
2. DBW, there's no reason to change it!
3. You'll prbably have to mod the headers unless they fit an LS1 application for this combo.
4. Not sure on this one, try contacting Kinsler or someone.
Although personally I probably wouldn't go LS7, they cost far too many $$$. I'd probably build a nice 402ci from an LS2 based block, decent cam & heads and some form of FI. For less money I'd expect to see more HP.
