Inertia Fuel Pump Cut Off
Old Sep 5, 2006 | 12:49 PM
Andy1's Avatar
Default Inertia Fuel Pump Cut Off
Does Chevy employ the use an inertia fuel pump cut off like Ford does on it's EFI? I've never seen it mentioned here. I would think it's an important safety device worth having in case of accident. Cuts off power to the fuel pump upon impact or roll-over.
Andy1
Old Sep 5, 2006 | 12:52 PM
91sbcamaro's Avatar
As far as i knew ford was the only one doing that. I bought a 00' Camaro that had been rolled over and the engine and everything still works great.
Old Sep 6, 2006 | 11:37 AM
Andy1's Avatar
ttt
Andy1
Old Sep 6, 2006 | 12:00 PM
RFERG43's Avatar
The Chevy PCM takes care of that.
Old Sep 6, 2006 | 12:23 PM
Andy1's Avatar
Are you saying that the Chevy PCM has an integral inertia switch? Does it reset itself?
On Fords, if someone bumps your car hard enough in a parking lot, it will trip the switch. It must be manually reset; it has a reset button on it. The switch in my Explorer in just under the dash on the passenger side.
Andy1
Old Sep 6, 2006 | 12:46 PM
icantdrift's Avatar
i believe the pcm only cuts off the pump if the engine stops rotating, which is what most manufacurers use.
Old Sep 7, 2006 | 12:40 AM
Gen3Benz's Avatar
Andy1
which ford still uses one?
Old Sep 7, 2006 | 10:57 AM
Andy1's Avatar
As I mentioned, my Explorer has one.
Ok, let me re-phrase the question:
Is there any provision in the late model GM cars/trucks with the LSx series motors that use any type of fuel pump cut off in case of accident/impact/rollover, etc?
58psi fuel spraying all over the place after an accident sounds just a bit dangerous, does it not? Sure seems to me that the manufacturers (all of them) would somehow address safety this issue. Anyone know for sure?
Andy1
