Need a list... LS1 mustang swap
I am in same I8URLS1 from TRS. What do you post as over there? Anyways I am going to address AJE about this problem in the process of ordering everything... What would I need to tell him to do to correct this issue?
Also I found out today D&D makes a plate that bolts onto the front of the T56 so I can just run the stock clutch setup. Takes a little modifying of the bellhousing is all but will alleviate a lot of problems. What r u guys doing for a crossmember for the T56's?
Heh I wish I'd known about D&D's adapter before we fabricated my hydraulic setup
Oh well.
I used the 94-95 T5 cross member and frame mounts, we just cut them to fit with my subframes and then welded them in. If you don't have subs then you can just fit them right over the rails. Then I drilled holes for the stock GM tranny mount to bolt in. We also had to make a 1/2" spacer to go between the crossmember and the tranny mount, to maintain the correct angle.
I don't post there but I saw the "for sale" section, with all the Ford stuff for sale with the same name
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Do you have any more information about it?
As for a crossmember, my stock '96 Cobra crossmember bolted right to the T56 after rounding out one of the stock mounting holes.
Oh well.
Originally Posted by Mystic96
Do you have any pics or info about what you fabricated for your clutch setup?
I'll have to take some pics but I'll attempt a description. Basically I swapped in a T-Bird turbocoupe clutch/brake pedal setup, then copied the factory setup with a shorter master cylinder from Wilwood. We fabbed a bracket to hold it in place so that the pedal lever can actuate the master. Hooked a -4 line directly to the master with a MacLeod custom line from Summit that has the quick-disconnect. Viola! I had to buy the master and the line, and then a few bucks worth of scrap steel, paint and a few grinder discs. Probably alot cheaper than D&D's adapter, at least I hope
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
I called D&D when I was researching a clutch setup and they didn't have anything like this and no mention of any type of cable style setup for the LS1 T56.
Apparently it is designed for the cobra T56 from what I was told but with some modification to the bellhousing will work with the f-boat T56. I will try and get some more info. I know it's about 3-4 hundred but well worth it in my opinion. Maybe he had the companies wrong but I doubt it. I am just going to have my buddy call and order it from his shop probably within the next two weeks.
I8URLS1 posting from this SN
I just called D&D and the only type of bolt on adapter they sell is for older cars so you can bolt a T56 onto a 4 speed style bellhousing to be able to use the stock clutch linkage. Said I'd definately have to convert the Mustang to a hydraulic clutch setup.
I just called D&D and the only type of bolt on adapter they sell is for older cars so you can bolt a T56 onto a 4 speed style bellhousing to be able to use the stock clutch linkage. Said I'd definately have to convert the Mustang to a hydraulic clutch setup. ![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
#32
#33
So I think we are all curious as to how Mr. Hydes header install went. Did the macs fit no problem? I'm hoping someone finds a worry free header by the time I reach that stage. Otherwise I'm gonna have to cough up the cash for some custom 1 7/8''s longtubes.
#34
