Crank trigger sensor and cam position sensor
Old Sep 12, 2006 | 10:23 PM
ls1_chevelle's Avatar
Default Crank trigger sensor and cam position sensor
Can either of these be bad and still allow the engine to run? My dad is kicking my *** about my tach STILL not working and the initiative is he's gonna pay for my 3:73s.
I have check the pin 10(white wire) and its in the correct place. Tried 2 ECM's and 3 tachs and still nothing.
The tach needle doesn't even jump or do anything. Tach signal is set to 4.
I read while searching that there is a seperate ground wire for the tach signal wire??? I havn't checked that out yet.
If worse comes to worse I'll drive up and get a shop to plug in and see if it shows a tach signal.
Thanks gang!!!
-Matt
