LSx into a 944 porsche
Andy1
Andy1
Someone mentioned something about the 951 trans having better gearing- I disagree. The 951's 5th is WAY to low to get to top speed or conserve fuel. Alot of people get the 951 trans and put the 944NA 5th in there. The issue with the 944 transmissions though is that even the 951 will break with the high torque of a LS V8... One of the few reasons why I'd be happy with a stock LS4 with DOD- 300HP in a 2700lb car is pretty decent in my book!
Check it out...
http://www.560sec.com/bulletinboard/viewforum.php?f=2
look at Renegade hybrids, they got kits for it, and they are nice.
DoC
Not a good idea imo. I have heard of a lot of problems with the 968 trans. The bushings in it can beat out with just the 3.0 in front of it, nevermind an LS! Just stay with the cheaper and strong 951 trans (which also many times comes with lsd). If you wanted you could also put a torsen in it.
check out
http://www.renegadehybrids.com
they have pics of customer cars and completed cars all around.
Actually the 6 speed was almost entirely for bling factor. The 3.0L engine has a very flat torque curve and would be fine with a 5 speed. They put a 6 speed in it "because Porsche drivers like to shift".
Did you use a Renegade kit? or fab your own mounts etc?
Can you put the 968 trans in a 944?
Thanks
