LSX into BMW
Old Sep 17, 2006 | 12:51 AM
lightning95sc's Avatar
Default LSX into BMW
I'm wondering if anyone here has contemplated, done or seen an LS motor swap on a early to mid 90's BMW 5 series?
I'm looking at a well used 528 wagon. Instead of putting ANY money into a 2.8 6cyl I'd rather spend the money on a 6.0 and make it truly entertaining. By the way, I'm used to driving a Volvo wagon with a 5.0 conversion and a blown Lightning. Chuck
Old Sep 17, 2006 | 02:08 AM
jfman's Avatar
there's a guy that made one fit in an E36 (318) so I cant see why it would not fit in your car.
I have also seen it done in a E30 M3....
Go for it man !
Old Sep 17, 2006 | 02:34 AM
redmist's Avatar
I did one into a 1977 BMW e12 5 series and a 1983 E21 3 series. Believe it or not the front frame rails are the same distance apart. A 5 series wagon would be cool. The rear diff, axle shafts and CVs can handle the power. I had a conversion driveshafts made to go from the T56 to the BMW diff,
The only challange with your 5 series is if you have a steering box versus a rack and pinion. If you have a box then you might have to switch it out for a rack.
Old Sep 17, 2006 | 10:35 AM
Thanks for the encouragement. I'm sure this conversion has got to be easier than a 5.0 in a Volvo. Which is not really that difficult, but it gets real cramped real quick. Chuck
Old Sep 17, 2006 | 11:43 AM
Cam72aro's Avatar
Default bmw
What year is the wagon? Is it e34, or e39? I agree that it would be really cool, and upset alot of mustangs. Leave the stock wheels and all for that grocery getter look. I think the only problem is the trans tunnel, might have clerance issues.
Old Sep 17, 2006 | 12:02 PM
BLKWS.6's Avatar
Ls1 in a Z3 or 4 would be OBSCENE, but BMW has an equivalent, its the Z3M.
Old Sep 17, 2006 | 05:15 PM
bimmers4life's Avatar
im sure it would be a lot easier than an ls1 into an e30 like i was going to do. The 5 series has a ton of room in the engine compartment. During the planning stages of my swap i was debating on weather or not i should sell my car for a 5 series instead. good luck keep, us updated!
Old Sep 18, 2006 | 07:18 AM
chuntington101's Avatar
there is a guy on this forum that has done a LS into a Z3! looked almost stock when he finished!
will try and dig out a link for you.
Chris.
Old Sep 18, 2006 | 09:40 AM
owen v8litew8's Avatar
LS1 5series wagon?
nice family hauler, good luck on the project, I'm sure it wont be too hard.
Old Sep 18, 2006 | 10:28 AM
jeepinpete's Avatar
I had a MZ3 for a couple years, and there ain't no way it would keep up with a LSx equipped Z3. I played with a C5 once out in OR, and he would walk away from me at will. It was a hugely entertaining car, lots of fun to drive sideways, but BMW makes power by RPM and gears, not natural torque. A Z3 with a LSx would have to be a sub 5 sec car. I sold the car, and regret it every time I thing about it. I dream of putting a LS2 in a MZ3...
Old Sep 18, 2006 | 01:56 PM
jfman's Avatar
Which version ? the 240hp version or the 330ish ho version ?
Old Sep 18, 2006 | 02:10 PM
are BMW still giving you guys the lower powered version of the Msport engines???
just wondering cos we get the full 340bhp stuff over here (uk)
Chris.
Old Sep 18, 2006 | 02:41 PM
Cam72aro's Avatar
Default horsepower
Chris.
Are you referring to the s54 engine? In the e46 m3 it makes 333hp. I am not exactly sure about the new e85 m roadsters. I think it is the same. I know they are pretty quick. We have had a few roll thru the dealership.
Old Sep 18, 2006 | 08:10 PM
redmist's Avatar
One more thing...
The vette oil pan makes things a lot easier regarding the crossmember. That's what I used in the e21 bmw. The oil pan is even with the crossmember so you can lower the wagon quite significantly without any issues. It also enables you to line the tranny and diff in a very straight line.
Old Sep 18, 2006 | 08:26 PM
Sparetire's Avatar
www.vorshlag.com
Also, go to Bimmerforums.com and search the E36 specific forums for "LS1 E36". I think it was start by a guy names Franchise or Fair. Either way, the thread title is Ls1 E36 and its a great read.
The reason I think this is pertinent to your 5 series is that the guys at Vorshlag have done a spectacular development program that puts most other hybrid operations to shame. They have prototype headers and steering shaft mods just so that they could perfectly place the engine in the car for optimal weighting (they are big F-Body autox guys and love M3s). If they can make it work in a E36, then simply doing some different mounts will probably be enough to use their kit (whenever its gets tested and produced in its entirety). And you will probably have tons of room to boot. I suspect wiring will be very similar between the two.
Old Sep 20, 2006 | 06:39 AM
JoeZ's Avatar
THere are some pics floating around of a guy who did a twin turbo LS1 setup into his 5er but I've never found any details.
I'm almost finished with my LS1 into 1996 Z3 and have a couple threads going https://ls1tech.com/forums/showthrea...4&page=2&pp=20
more recent pics https://ls1tech.com/forums/conversions-swaps/578304-couple-more-ls1-into-z3-pics.html
Badass 5er
