mechanical temp sensor
Old Sep 20, 2006 | 09:47 PM
Cam72aro's Avatar
Default mechanical temp sensor
Has anyone ever put a mechanical temp sensor probe on an ls1? If so, where? I will eventually will put a electrical sender on my motor when I update all of my gauges, but would like to use the mechanical one for now.
Old Sep 20, 2006 | 10:05 PM
88s10's Avatar
I drilled and taped the brass freeze plug some body makes a temp sensor adapter at this time I just cant remember who. Maybe some body will chime in on who makes the adapter?
Old Sep 21, 2006 | 09:51 PM
Cam72aro's Avatar
Default ttt
Anyone have any ideas?
Old Sep 22, 2006 | 01:32 AM
POWER ON's Avatar
This is on the right rear cylinder head of a 5.3
Thanks
Old Sep 22, 2006 | 06:19 AM
Cam72aro's Avatar
Default adapter
Where did you get that adapter from? Thanks
Old Sep 22, 2006 | 12:17 PM
POWER ON's Avatar
It's part of the Autometer kit 3/8-18. You need to tap the 12mm hole to 3/8-18. It is the best reading you can get.
Thanks
Old Sep 23, 2006 | 02:27 PM
88s10's Avatar
hotrodlane.cc sells the 12mm adapter
