tach/ls1 help
Old Sep 21, 2006 | 06:19 AM
s10_ls1's Avatar
Default tach/ls1 help
i think i need an eletric tach but not 100% positive wanting to go ahead and get the tach and wanna make sure i get the right one thanks in advantce
Old Sep 21, 2006 | 06:57 AM
Jones'n's Avatar
I thought all tachs are electric??
What year is the truck it is going in to? Chances are you won't need to do anything, the stock gauges should work.
Edit: Looked at one of your old posts. Truck is a 95 2.2. The tach will work just fine, you don't need to do anything.
Old Sep 21, 2006 | 07:07 AM
Jhankinson's Avatar
my S10 is a 1994 2.2 originally...and the tach worked without any problems...is very accurate...so you shouldnt have any worries. All you have to do is tie the tach wire into the white tach wire origianlly in the truck...even if the truck originally didnt have a tach cluster, you can switch to one cause all the tach wiring is still there.
Old Sep 21, 2006 | 08:43 AM
G-Body's Avatar
sawzall wielding director
Almost all tachs are, but there are some older tach`s that were mechanical. Scooter 70 has one in his vette, it was a factory install. I don`t remember what year that GM stopped using them, sometime in the 70`s I think.
