Where to find info for Jeep CJ-7 conversion?
Originally Posted by CorvettePD
Looking for info on a 5.3 + T56 conversion for a CJ-7. Can any of you point me in the right direction?
Thanks
Look up or call Advanced adapters(not sure on spelling) They make swaps for darn near anything-mounts,cradles,etc. Quadratec catalog has lots of swap parts also. Fairly easy swap-you can buy the rad,headers,eng,trans mounts,etc. You will need to tear the tranny down and change the output shaft-rear housing most likely to adapt to a transfer case. I'm not sure if any one makes a shaft/adapter for this swap. I would use a 4l60e/700r4 or an nv3500/4500(manuals) for trannies. I have built a few cj's from the groundup also,could prolly help ya dig up some info adn what not,but alot of guys are using the transmissions I listed. Good luck and have fun bro
T56 will be a big obstacle. It has never been offered in a 4wd variation. Therefore, there is no tailshaft housing set up for mounting a transfer case.
You have 2 choices:
1.) Build (or have built) your own tailshaft housing (or modify a stock one) to mount the transfer case. This has been done, Mark Stilow (did I spell his name correctly) built just such an adapter / housing when he built Quadraduece.
2.) Punt. Drop any dreams of having a T56 in a 4wd jeep. Either ditch the T56 or 4wd, your call really.
Sorry to rain on your rockcrawl (I figure you're not the parade type).
'JustDreamin'
You have 2 choices:
'JustDreamin'
