LS4 in MR
Old Sep 26, 2006 | 08:48 AM
Carver's Avatar
Default LS4 in MR
Looking into shoving an LS4 into a Mid engine rear drive.. and have a few issues..
1. Throttle body is 100% drive by wire on LS4, and i have a cable... should i source the pedal position sender for the ls4 TB? or can i just plug in and not use (let dangle basically) the ls4 TB and run an LS1 throttle body off my cable? Will this be sufficient to 'fool' the system?
2. Also, will I have to run O2 sims (cattless). I am not worried about cel's but i am worried about being thrown into some kind of low power or limp to dealer mode.
3. Plan to turbo at a modest 5psi. I am wonering if i can get away with stock computer/injectors, and just tune by a raising rate fpr, say at 1:1 or 2:1 and trust in the MAF meter, and a Methanol inj. kit?
thanks
Old Sep 26, 2006 | 10:07 AM
Brains's Avatar
PCM tuning will be your friend. You can flash the PCM with a profile matching whatever hardware configuration you plan to run. So, you can run a cable throttle body, the O2 sims become unnecessary, tune the PCM to properly fuel while in boost with whichever FPR you choose, turn off the VATS security so it will actually start and run, etc. all with PCM tuning. There's no need to "fool" anything, when you can make it all operate properly and happily. The check engine light can even be made to respond properly by enabling or disabling the appropriate tests and test responses.
Old Sep 26, 2006 | 08:27 PM
Carver's Avatar
did not spend too much time looking into this, but it looks like HPtuners is the way to go-
Old Sep 26, 2006 | 08:46 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Since the LS4 uses the new E40 ECM I would stay with the electronic throttle and just add the ETC pedal to your project vehicle. It works very well!
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Sep 26, 2006 | 11:46 PM
Carver's Avatar
grrr, two posts, diff. advice...
Old Sep 27, 2006 | 06:56 AM
Brains's Avatar
That's the thing-either way will work, with the proper parts/PCM/tuning combination. There's literally enless possibilities. Speartech has a handle on all these options, its the root of their business.
