LS1 S10... questions
- Which Slave cylinder I would use, LS1 or stock 4.3
- Which pedals..stock 5 spd?
- What radiator will work?
- If I use the 5.3L oil pan does the crossmember still need notched?
- Also I have the stock 1 legger rear end, will the LSD from an F-body bolt into my rear?
Any other general info about this swap is greatly appreciated...
Thanks, Matt
https://ls1tech.com/forums/conversions-swaps/424515-s10-ls1ers.html
use the stock pedals and clutch master.
use the LS1 slave, make a new line to connect the S10 master, and the T56 slave
the stock 4.3 radiator works fine.
so far, there isnt an oilpan combination that doesnt require some notching of the crossmember.
yes, the center section and gears from any 93+ Fbody will slide right into the S10 housing with no mods whatsoever.
tha all aluminum construction of an LS1 makes it a far superior heat exchanger than the all iron 4.3.
Do a search about that company around here and read all of the horror stories. Then ask about the 2 or 3 lawsuits he has against him.
lol, very true.... but they DO make one =]
actually, if you are converting an S10 of later years, 97 Up, possibly even earlier.. if it was originally a 4.3 and 5 speed from the factory, it will have an 8.5 inch rear end and the posi from the F-body won't interchange..
the disc setup will though.....
so you have a stronger rear end, but will have to source an 8.5 posi carrier....
just an FYI....
I bought a 8.5 out of a '95 Silverado $125 strip it narrow it build it for under $1200.
