Crate Engine -> No MAF-> What do I need?
Old Dec 16, 2006 | 07:45 PM
ewingr's Avatar
Originally Posted by pist0lpete
Try to avoid runnig the maf/filter combos that come straight off the throttle body as they end up sucking the hot air from behind the radiator causing you to lose at least 10-15 horsepower once the water temperature is up to operating range.
I do plan to do a cold air intake. I presume you can put the MAF anywhere in that aire intake. Right?
