Crate Engine -> No MAF-> What do I need?
What specifically do I need? MAF, Maf Sensors? Of course Air Filter.
Are there different types, and is so, how do I know which I need.
Thanks for any advice.
Are all MAFs the same, or does it require a specific one. What other parts, as it relates to teh MAF and things in front of the TB do I need?
In answer to your questions, I do have a tranny; I do have a computer; I plan to purchase a harness from Speartech.
I am having trouble getting the right flex plate. The one that came with the engine (Corvette) of course won't work. I purchased one from auto parts for a 2002 Camaro, and doesn't fit the torque converter. The tranny is for an '05 Chevy 5.3 truck, I think. I'm told I probably need a dished flex plate.
You'll need to have your PCM reprogrammed. this thread discusses what's needed http://www.hptuners.com/forum/showth...ty+disable+maf
What do I need to know to be sure I get the right one? For example, I see one on ebay listed as BRAND NEW and GENUINE AC Delco 3 1/2" LS1 Maf Sensor. At this point in time, I don't know if 3 1/2 " is what I have a need for or not, or if there is eve a different sized one. It is listed at a reasonable price.
Also, they say "use it with our MAF translator". Is that somethign else I need?
So all in all given that my engine has a TB, and thats it, I need:
- MAF
- Translator
- Filter
Is that right?
I guess the last question would be: Is there any reason to spend extra $ for an aftermarket MAF?
[EDIT]
Ok. I've done some browsing around. It looks to me like the translator is a tuning device, and not a component that goes on the car.
Other questions still apply.
if you _really_ have trouble, then you can hit ebay or your local parts store and tell them the year/model ls1 and they will give you the appropriate maf. used maf's should run < $50 and new ones < $150.
the engine harness should be all you need to connect it.
I've been doing a little reading since my post, and I see claims of 10-15 HP gains, and improved gas mileage, for the expensive afermarket ones.
Anyone know if there is any validity to those claims?
The LS6/LQ4 MAF (85 mm) is a good bit larger then the stock LS1 MAF, easy to have tuned for by mail order, and 50 bucks to your door (new) on Ebay most the time.
I'm pretty sure the LS6 85mm MAF is a 5-wire. What harness are you running?
QUOTE]
Please, for all those against "mail order tunes," tell me how a stock tune on a stock engine is a bad thing? Yes, yes, I know you can squeeze a few extra horses through the tuning, but is it really such a big deal?
If it were a modified engine (heads/cam/etc), then of course I'd be 100% against a mail order tune. Also, SD is pretty nice, but the MAF, when properly setup, gives a nice layer of redundancy for the closed loop system that I wouldn't remove unless I was drawing enough CFM to saturate it (thus making it useless).
Opinions?
I have no information on who would be a good local tuner, and if they aren't good, I expect it can be just as possible that it's worse than just a mail order tune. And extra cost and hassle.
Again, my goals are reliability, and decent mileage.
