LS7 crate motor in 79 Z28
Originally Posted by John B
Get the harness & ECM from Speartech and you can use an F-body T56 and you should be set once you decide whose motor mounts to use!
also, what motor mounts do you like? and where can I get headers for the 2nd gen camaro?
and I am thinking about adding the GMPP Stage III "hot cam", where can I get that?
thanks John. BTW, I love your car...
aslo, besides the cam and the headers, where is the best place to buy motor mounts? and where is the cheapest place to get the crate motor?
thanks John
thanks John
For motor mounts you can either get the adaptor plates from Trans Dapt (Summit or Jegs) or the adaptor plates from hotrodlane.cc I chose BRP motor mounts www.brphotrods.com
It seems that pacesetter headers for a fourth gen LS1 Z/28 will work with minor modification.
You can try www.gmpartsdirect.com for the engine or give Jason Cromer a call at Sam Taylor Buick in Florida as he gives excellent prices. I don't have his number handy but do a search on him here or at www.camaroz28.com
Marc
Marc
I have a set of aluminum LS1 to SBC engine mount adapters from hotrodlane.cc (aka Street and Performance) and I am a little suspicious that they are a too thick. It seems like most of the steel ones offered are a little thinner. I think the extra thickness is causing the motor to sit a little higher than intended and is causing my mounts not to match up correctly... however I am still investigating.
yes, I sure did. im thinking of getting the Edelbrock race victore 1 3/4 stepped to 1 7/8. I hear they fit 2nd gen's with "tweaking"
and thank you John, and everyone else.
BTW, I saw your car in a How to build a pro-tour book when you still had the ls1
where did you get your wheels?
