Oil an removal install?
Old Oct 9, 2006 | 04:20 PM
AaronH's Avatar
Default Oil an removal install?
Can the pickup tube be remove and installed without removing the front engine cover?
Thanks
Old Oct 9, 2006 | 04:25 PM
svt's Avatar
svt
yes, you can remove the pan then take off the 2 bolts that hold the pickup tube to the block and it'll come right out. No need to take the front cover off.
Old Oct 9, 2006 | 04:49 PM
AaronH's Avatar
Thank you
Old Oct 9, 2006 | 05:31 PM
mramay's Avatar
Reinstalling the pan is critical though, make sure it lines up properly.
Old Oct 9, 2006 | 08:26 PM
'JustDreamin''s Avatar
You might also think seriously about replacing the O-ring that seals the tube to the oil pump. Its pretty cheap, probably good insurance.
'JustDreamin'
