Procedure for first startup
Old Oct 13, 2006 | 04:52 PM
67RSCamaroVette's Avatar
just remove the plugs so there's no compression, disable fuel relay, and crank it.. it's simple. mine took about 20 secs of spinning to build oil pressure.
Old Oct 13, 2006 | 08:55 PM
LS1-IROC's Avatar
Originally Posted by RFERG43
Just below the oil filter is a plate covering two holes. Remove it and drill and tap a piece of aluminum to accept a small barbed fitting. The hole should be drilled so that it is over one of the holes in the block. Get a cheap oil pump sold at auto stores for filling transmission and diffs. Pump oil into the first hole until you feel the pressure build up then crank the engine over and repeat the process. Swap ends on the plate so the fitting is over the second hole and repeat the above. This will fill all the oil galleries and pump oil throughout the entire engine.
That's a pretty interesting idea...may have to look into that. I have a crate motor that's 6 years old without ever being fired up
Old Oct 15, 2006 | 10:38 PM
patriotformula's Avatar
ours was a crate motor... the place we bought it from said it was fixed so i guess we just let her rip, if it broke down send it back but you know what, haven't had one problem with it since and let me tell you its had a lot of abuse. It is hard to listen to the valvetrain for more then a few seconds but i guess whatever works. Sounds like RFERG43s method would work well tho...
