LS1'ed chevelle and driveshafts
Old Oct 15, 2006 | 01:16 PM
jfman's Avatar
Default LS1'ed chevelle and driveshafts
Can I use the LS1 Aluminum driveshaft in my 1970 chevelle ? (I know it prolly needs to get cut or lenghted)
What did you other A-body guyz ended up doing ?
Old Oct 15, 2006 | 10:56 PM
ls1_chevelle's Avatar
had my stock one cut.
-Matt
Old Oct 16, 2006 | 02:00 AM
jfman's Avatar
-Matt
Stock one .... ???
LS1 or chevelle driveshaft ?
Old Oct 16, 2006 | 06:54 AM
stealth71's Avatar
I have an aftermarket driveshaft that I will have shortened.
Old Oct 16, 2006 | 03:31 PM
pist0lpete's Avatar
I plan on having my stock chevelle one shortened. I have already had it shortened once for the 700r4 install so hopefully it will still work without shortening.
Old Oct 16, 2006 | 07:43 PM
jfman's Avatar
Is the ls1 Aluminum shaft too long or too short ?
If it's too short, can you get it lenghtened ?
I woul MUCH prefer having an aluminum shaft since I have it already ..
Old Oct 17, 2006 | 02:53 AM
malibuman69's Avatar
What setup do you have? I have a th350 behind mine and I used a driveshaft out of a 92 chevy 2wd truck 117.5 wheelbase and it fit like a champ.
Old Oct 17, 2006 | 10:43 AM
jfman's Avatar
T56 and a 10bolt rear end.
