Another LS14 Project.
Old Jan 9, 2007 | 08:18 AM
  #161
icantdrift's Avatar
Originally Posted by mikespeed95
one way is spelled h-i-n-s-o-n
"bolt in"
hinson can also be replaced with a synonymous word.... J-U-N-K
Old Jan 9, 2007 | 09:25 AM
  #162
datboibrad's Avatar
rofl at all the grammar pro's we have xD
Old Jan 9, 2007 | 09:00 PM
  #163
cnichols's Avatar
Originally Posted by datboibrad
i just wired up the sensors into the harness lol. if anything i wont have reverse lights. if you have a general understanding of wiring you can figure it out tho. its quite simple.
You can intercept it before the B1 plug, but I figured it would be easiest from the tranny to get to some point along that path. This should help anyone wanting their reverse lights to work. I have not tested it, but in theory it should work. Please let me know if there is a flaw in my logic or facts. (BTW: this is for an S14)
Old Jan 10, 2007 | 03:36 AM
  #164
datboibrad's Avatar
well **** lol. good find! ive spliced out the wires from the auto plug for what i need to wire up the 6 speed tranny. now i can easily wire the reverse lights in.
Old Jan 10, 2007 | 11:54 AM
  #165
hardtopz28's Avatar
Originally Posted by mayday0017
man you can say what you want be he just wishes he had someone like me working on that car I could make it happen I mean hell the guy is useing blocks of wood for motor mounts
yeah he wishes to have someone come screw his **** up.
Hey brad that project looks good man might stop bye one day to check it out
Old Jan 10, 2007 | 02:18 PM
  #166
cnichols's Avatar
well **** lol. good find! ...
I made it yesterday I've spent so much time looking through that damn FSM I can find stuff pretty quickly.
Old Jan 10, 2007 | 10:59 PM
  #167
mayday0017's Avatar
We made some good progress today just like we have for the past week or 2
  #168
datboibrad's Avatar
lol time for an update. resizing and uploading pics. stay tuned folks
ok so mayday and i got busy making the tranny mount and getting this mount **** wrapped up already.
just a little toilet humor. our welding "is the ****"
tranny mount setup. more of a race setup since its solid mount. will be one of two designs offered. ill probly get this cnc'd out of solid alum later.
just to give an idea of firewall clearance.
motor mounts finished
and of course the motivated assistant himself
Old Jan 12, 2007 | 01:46 PM
  #169
owen v8litew8's Avatar
nice progress, good pics, keep 'em comin' until you can smoke some tires!
Old Jan 12, 2007 | 03:41 PM
  #170
Cobra4B's Avatar
Question for you.... can you take any good upclose pics of your front cam bearing? I'm puttin a G5-X2 in my Z06 and just would like to compare mine's condition to yours. Something like these... (if you can) here's mine w/ 70k on them and 3-5 HPDE weekends a year, almost daily driving, redline everyday.
Old Jan 12, 2007 | 06:31 PM
  #171
datboibrad's Avatar
cam bearings are new to me and mine look like total ****. so they are being replaced. IMO i would replace them because they are cheap and easy.
Old Jan 14, 2007 | 03:48 AM
  #172
Slo_240sx's Avatar
Nice job bro! Keep it up.
Hinson = JUNK unless its their car or someone they sponsor. And even then its JunK.
Cobra, REPLACE those bearings or you will be buying a new cam buddy!
Old Jan 14, 2007 | 11:48 PM
  #173
mmdb's Avatar
Correct me if I'm wrong but it doesn't look like you modified the transmission tunnel. If not, how does the shifter sit in respect to the shifter hole?
Old Jan 15, 2007 | 01:38 AM
  #174
mayday0017's Avatar
The transmission tunnel was untouched. We did some beating of the firewall before the seams if your not sure what I am talking about um.. if you go back about 2ft from flat part of fire wall twords shifter we beat to there maybe even a foot and a half but not even half way to the shifter did we have to do anything... We maybe beat that part back 1/2" all the way around and we have good clearence you can slide your fingers around the whole transmission. The shifter sits with the hoop part above the hole and if you look strait down at it, it sits like maybe a centimeter from being even with the hole cut. We do plan on cutting the hole back approx 1" just to make sure we never run into any problems and so we can also unbolt short shifter with out dropping the tranny. If you go back a page there is a picture of where the shifter is going to sit.
Old Jan 15, 2007 | 09:15 AM
  #175
datboibrad's Avatar
the area he speaks of is really a in between area. its from where the firewall starts to where a seam is made by the chassis and where the fire wall ends. after that nothing is touched. but mayday pretty much covered it.
Old Feb 4, 2007 | 02:07 AM
  #176
GIGAPUNK's Avatar
and then...
Old Feb 4, 2007 | 02:58 PM
  #177
datboibrad's Avatar
Originally Posted by GIGAPUNK
and then...
? looking for an update or something? will have pics of a partially completed engine bay sometime this way. 12 hours of class and 35+ work hours are killing me lately so things are moving slow. tranny mount is being redesigned so swap can go back in. driveshaft will be made at that time as well as headers.
Old Feb 9, 2007 | 10:51 PM
  #178
Gen3Benz's Avatar
Have any 240 guys used the gto/corvette mount brackets?
They worked very well for my project and just required some pedestals be made to get the right height.
Your welds on your crossmember look like they could use more heat, kinda boogery. But I do like your wooden welding table.
Old Feb 10, 2007 | 05:01 PM
  #179
the.erinyes's Avatar
No one has used them todate that have posted on this board. I am looking at the feasibility of using them.
Old Feb 10, 2007 | 07:59 PM
  #180
fouz65's Avatar
just a quick question for you 240/ls1 ppl. did any of you upgrade your fuel lines? are the stock 240 lines big enough? just wondering if they work ok with the ls1. i dont regret changing mine just wondering if it was a must.
