Aternator Not Charging
Old Oct 20, 2006 | 01:42 PM
bczee's Avatar
Default Aternator Not Charging
I am going to see if I can reslove my charging problem this weekend..
I have a 99 LS1 and PCM, I have found in the FAQ that the C2 Pin #15 goes to the Alternator Term B to excite alternator to start charging.
Question. What voltage should I be reading from C2 Pin #15.. 12+v or less (5v ?)
I read that the 98 get a resistance or dropped down voltage from the warning light. I don't want to blow the alternator debuging it with the wrong voltage and checks.
Thanks.
Old Oct 20, 2006 | 06:27 PM
stealth71's Avatar
I don't know if you have this.
'98 Charging system
Do you have a resistor or bulb inline? Might just take it to get tested so your sure it works.
Old Oct 20, 2006 | 09:37 PM
G-Body's Avatar
sawzall wielding director
C2 Pin #15 should be putting out around 11V or at least that was what mine was putting out when I checked it. Check the red wire as it goes into the plug that plugs into the alt. I have heard that the wire is fragile and tends to break as it enters the connector.
Old Oct 20, 2006 | 11:37 PM
bczee's Avatar
Thanks G-Body.. i wasn't sure on the voltage.. I knew the 98 setup use the bulb/resistor.. but couldn't recall for sure. I will check it.
