Oil temp sensor location/adapter
Old Oct 24, 2006 | 07:42 PM
Bimmer Tech's Avatar
Default Oil temp sensor location/adapter
I'm in the process of fitting my Autometer senders in my LS1 and I'm having trouble finding a spot for the oil temp sender. I was thinking of just putting in the drain plug, but I can't find an 1/8" NPT to 12 x 1.75 adapter. Only other spot would be the pan itself. Are you guys drilling and tapping the oil pan or modifying the drain plug somehow? Thanks!
Old Oct 24, 2006 | 07:56 PM
70 LS1's Avatar
Conversion master
Are you already using the plate above the oil filter for something. This is where the corvettes had their's and where a lot of people drill and tap for oil pressure.
Old Oct 24, 2006 | 08:01 PM
That plate is gone and the holes are being plugged....my starter will reside there.
Old Oct 24, 2006 | 09:18 PM
TwistedSS's Avatar
LS1 fierro? LOL wow. Crazy swap man!
What about on the back of the block where the pressure sensor is, put a T in there and run both.
Old Oct 24, 2006 | 09:39 PM
I was thinking that. I have to run the intake backwards though, so I have to do some plumbing for the oil pressure sensor anyways.
Old Oct 24, 2006 | 10:49 PM
G-Body's Avatar
sawzall wielding director
Are you using the oil level sending unit in the pan? If not that could be another possible location. I don`t know what size it is though.
Old Oct 25, 2006 | 11:22 AM
Does the PCM use the oil level sensor as an input? As long as the sensor bung isn't too high, it might work.
Old Oct 26, 2006 | 11:34 AM
kwkenuf's Avatar
The oil level sensor just triggers the light in the dash, the PCM doesn't care what the level is....
Old Oct 26, 2006 | 11:42 AM
bczee's Avatar
I beleive I have read that the Oil Level sensor thread is 20mm x 1.5
Old Oct 26, 2006 | 08:19 PM
If so, that would be perfect as long as it is low enough in the oil pan. Thanks!
Old Oct 27, 2006 | 09:35 AM
Scooter70's Avatar
Well, since it's there to sense when there's enough oil in the pan, it should be submerged at all times. I'd say that's as good a place as any.
