lsx foxbody - motor plate vs. aje tubular
I use the QA-1 tubular for the 4.6 cars, and they work perfect. There is plenty of clearance between the rack, and oil pan, and I have about an inch between the passanger head and the firewall. I'm building 2 cars now, and will take some pictures so you can see. You can get the k-member and a new set of 4.6 motor mounts for about $300.
Jamie
Jamie
buy the aje k member, they make solid plate mounts, the vibration is very minimal. i am running the chevy t56, aje told me they made the trans crossmember, they sent me 2 that both didnt work!, i ended up keeping one, cutting the center section out and welding it myself.
check out some pics --->
http://viewmorepics.myspace.com/inde...lbumId=1194708
