Correct LS1 Fan Diagram Here
Blue Conn. Pin #42 : Low Speed cooling fan relay Control (Relay 1)
Green Conn. Pin #33: High speed cooling fan relay. (Relay 2/3)
More Discussion here:
https://ls1tech.com/forums/conversio...y-pinouts.html
One diagram shows terminal 85 get the ground signal from the PCM and terminal 86 to get switched power see first picture
Now I drew a diagram for this write up but can't post it but I will post the write up and it states that the PCM sends the ground signal to terminal 86 and switched power goes to 85 does it matter and if so where does it go
