Battery wiring question (starter, ground, alternator, etc)
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Ok, so wiring is done sans one relay I need to setup for fuel pump.
I'm searching around the forum and not having much luck...due to short lengths on my stock battery cables (2001 WS6), I need to rewire my battery terminals. I need to first figure out the stock wiring... I have:
Off my red (+) battery connector, I have two red wires and one black wire. They are as follows:
1 wire to passenger side (starter - red wire).
2 wires to driver side (alternator - black wire, there is a red wire, don't know where it goes)
Pics of the red battery terminal with the wires are here: http://www.satellitehead.com/images/...ival%20004.jpg
Pics of the connection on the end of the red wire (unattached) are next to the cinder block on the floor in this pic: http://www.satellitehead.com/images/...ival%20004.jpg
Off my black (-) battery connector, I have two black wires, one skinny ground (to frame or body?), one large (ground to block). They are as follows:
1 black wire to passenger side of block here: http://www.satellitehead.com/images/...%20%288%29.jpg
1 black wire appears to be a ground to ??
Got some questions...
1) Why is there a black wire coming out of the (+) pos side of the battery to the alternator? Seems like it should be red.
2) What does that (+) red wire ?(on floor in pic above) go to in the stock vehicle? I couldn't find a place to hook it up...![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
3) What did the ground hook up to... Frame, or body?
4) What gauge wire is this? 6ga? 4ga?
So, looks like 5 wires total that need hookup from the battery. Just curious what the heck they are![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Any help appreciated, or, if you know this has been covered in another topic, please point me to it. Most of the stuff deals with the main harness, but I can't find anything on the battery wiring at all.
One more picture: Here, so you get a good look at both connectors:
http://www.satellitehead.com/images/...swap%20050.jpg
Red (+) has one black, two red wires.
Black (-) has one large black, one small black.
Black wire on (+) side is the one that's stumping me. Looks like it sould bolt to a block or something, but ... no clear indicator what/why.
Ground is very small, I assume it goes to body.
OK I will help you out a little...on the + side..your are correct..big wire goes to starter...small black goes to alt....and the other small red goes to your + acc feed...in some cases its a + post near the underhood fuse/relay panel...on others it feeds the main distribution for the car itself.
On the - side...the large goes to the block just above/in front of the starter, and the small black goes to the frame/body (depending on what you have) or you can loop it to both, thats what I did...also you should have a ground going from the pass side of the block to the body/frame as well.
Hope this helps...
J-
Hope this helps...
J-
I'm not overly concerned with wiring like the donor vehicle, I just want to verify what the heck that wire was! I had no idea ![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Ok, so what I'm reading here is that the extra (+) red wire was basically the power line for everything *inside* the car. This is what I suspected. (thanks, J, I appreciate you clarifying
I also appreciate any similar grounding tips from others. I'm limited to bolting battery->body on the small ground, and I will probably run a ground from batt->frame as well, and block->frame. (might as well).
You can never have too many grounds with a fuel injected system.
On my S10...I grounded from Batt to pass side frame (bat is on pas side in bed)...from pass frame to pass side block....from driver side block to driver side frame...and then from frame to body. I used the stock - bat cable for the bat to block and frame connection. But the others I used 4ga wire. It works extremely well for my use and no issues thus far. If i did it again...i would ditch the factory cables and run a 2ga wire for gounds and + to starter...then a 4ga for the alt + and main power lead inside.
J-
J-
I grounded my Chevelle this way.
Battery Neg post to the Frame, body and Engine (front of head).
From the Engine motor mount of each side to the X-member/frame.
from the back of the Heads to the Firewall.
The PCM ground pin to the Firewall, used the same screw/post as the back of the engine ground strap to firewall, just on the other inside of the firewall.
What gauge wiring are you guys using for your battery cables, and where did you pick it up? (Pls note, I am not in a coastal city, so going to West Marine or similar boat store is out of the question - that's where I would normally go
Did you go with a side-mount setup (male post), or a top mount (female clamp)?
Do any local auto part stores sell battery cable fabbing kits at a cheaper price than buying individual parts?
Any other tips appreciated. I'll add to my buildup thread later. I finally got my fuel lines done last night and I'm ready to finish wiring, slap in a battery, add some coolant and do a test fire (fuel lines were too damn easy, shouldn't have procrastinated so long!
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
1. Engine and trans to frame.
2. Frame to body
3. Battery to frame.
I ran 4 gauge for everything. I use and always have used the same wire used in car stereo installations.
Remember to keep your grounds as short as possible. Having them longer increases the chance of overheating. And of course clean the contact area to bare metal, don't just rely on the bolt threads to be your contact patch.
2. Frame to body
i use 2 gauge for everything. advance auto sells it in bulk cut-what-you-need. they sell terminals as well. i solder and heat shrink everything. and i run way too many grounds to be safe. you can never have enough ground straps.
Thanks, guys. I went to Napa today and got two universal side-mount posts, 7ft of 4ga wire (alternator) and 4ft of 2ga wire (starter). I don't need to tinker with the ground cable because they're just barely long enough.
At this point, I can't find anyone who carries the special 'ring terminal' for the starter end, nor the ring terminal for the master ground, nor the ring terminal for the alternator
I figured Napa would have these, since they seem to have connectors for everything else, including the firewall bulkhead on my truck, but .... No dice.
Does anyone have a source for the individual connectors so I can make my cables look a little more like professionally modified stock cables?
