V6 to LS1 Conversion, any volunteers?
Ok, I seem to come up with some crazy ideas at work while working on cars for some reason or other. I know this can be done with proper planning. Let's say someone had a ~2000 V-6 F-body M5. I was thinking of everything that would need to be changed to convert the drivetrain to a LS1. Service Manuals are not a problem at all and will probably be put to good use if this ever does happen.
Of coarse there's the engine and transmission, got that part of the swap covered. The subframe is different, so that would be needed, one of the lightweight chromoly would be acceptable also. If it is a M5 car I would think it would be better to go with the M6 over an auto, if it was an Auto car to begin with I would leave it Auto.
The PCM has a different part number. The engine wiring harness is also very different. Not sure about the underdash wiring harness. What about the tachometer? Not too familiar with the PCM wiring going back into the interior, is this a bulk connector, or is it just a few wires run through a grommet? Opinions on keeping everything functional as a new car?
All the engine accessory brackets would be different. The power steering pump could possibly be used with the correct reservior, brackets and hoses. Air conditioning would need compressor, AC hoses. Radiator may possibly work, better to get V8 replacement IMO. Alternator replaced with V8 version.
Now on a factory M5 car, would the clutch master be the same... The V6 line still has the quick connect at the slave cylinder which should be the same. Driveshaft should be the same length. Not completely sure of Torque arm. Rear axle housing same, except with an open carrier.
Of some interest is the V6 cars have a fuel pressure regulator with a fuel return line from the injector rail, possibly use the 97 C5 fuel rail with a higher volumn fuel pump. Air Induction or Exhaust shouldn't be a problem, use factory LS1 parts.
Lets assume everything for the swap was for same year model to make things easy.
I am mainly concerned about how the V8 PCM and engine harness will mate with the chassis wiring under the dash, not looking for exact replies, just thoughts on how this would or wouldn't work. <img src="images/icons/grin.gif" border="0">
Possible benefits are V-6 car looks like V-6 car on the outside, no emblems. V6 car has V6 car insurance. Could the V6 car body be considered a sleeper with a quiet or hidden exhaust?
See I said at the beginning I do ALLOT of thinking at work <img src="images/icons/shocked.gif" border="0"> Did I leave out anything that would be a BIG surprise...
Please no responses on why someone would do this, this is all in Theory and all Technical data is welcome as this is meant to be a Technical Thread <img src="images/icons/smile.gif" border="0">
Tony
I may do the first one, I should still have less than $18K with everything and a little extra <img src="images/icons/wink.gif" border="0"> I'll actually skip the "stock LS1" step everyone else has to deal with. <img src="images/icons/grin.gif" border="0">
I wish GM had a uncompleted Z28 chassis like they do with the Z06's, it would make it so easy.
J.
[ November 20, 2001: Message edited by: Crazyquik ]</p>
Jeremy
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
<strong>Put a LS1 in the '67!!</strong><hr></blockquote>
ROCK ON! Now THAT would be kick ***! I still say that I'm gonna throw an LS1 in a '67 Chevy II or 1st gen Camaro before I die. <img src="images/icons/smile.gif" border="0">
LS1...except those 67 cars are hard to find these days...
