ls1 s13 240sx completed
becuase of the g forces the oil actualy moves away from, and stays away from the pickup tube, the extra quart fixes the issue. you dont have to worry about the crank foaming the oil becuase it has a windage tray and some baffaling between the pan and crank
and again bro good job on the swap
car runs great no probs with motor . oil pressure right on . drifts like crazy .
only thing is a power steering fluid leak .. has anyone had problems with the resivour .
the nipple comming off the bottom i think is leaking .. removed hose inspected put a efi style hose clamp on the hose still leak persist . wtf .
need a new hose. it has several o rings in it that will leak no matter what if they fail.
gm at the resivour -------------- 240sx fitting to go into rack
drift suspension
kts coilovers
largus sway bars ( only rear right now front dont fit b/c of the oil pan )
solid subframe mounts
spl tie rods
nismo power brace
full adjustable control arms
pritty much drifting suspension
i do have plans .. but no to shure on what to go with . i DONT whant more power . 324whp is enough to drift . so no cam . im gonna just do valve train stuff to help with the revs and holding wot for long periods of time
ls6 ported pump is already in
springs
retainers
lifters
pushrods
maybe rocker arms
btw ive been meaning to get at you about how you got your turn signals and all that harness intergrated jazz to work...
