ls1 s13 240sx completed
Old 02-07-2007, 07:44 PM
  #61
NoClassic's Avatar
Ls1neezy any idea if the A/C compressor will fit with your mounts setup?
Also how much did you have to beat on your tunnel to get the tranny in there?
Old 02-07-2007, 09:05 PM
  #62
ls1neezy's Avatar
have no clue if ac will fit .. never botherd to check .. tranny tunnle has to be pounded back quite a bit . i hammerd it back alittle more then i needed to .
Old 02-07-2007, 10:32 PM
  #63
datboibrad's Avatar
just because this thread has been bumped. i found a solution that in theory is going to work for the wipers. i just cut out the f3 plug and wiring off my ka and just supplying power as well as leads for the ls1 outputs for gauges. etc.
Quick Reply: ls1 s13 240sx completed
