ls6 into 2000 camaro help
A budget of 4500 will never happen. Sorry... Espeically if you want LS6 status. Ill bet, if you dont buy a donar car, and you get a motor and tranny for anywhere near $4500, you will atleast spend another couple grand easy on little parts. Like mentioned above...the nuts and bolts of the swap is what kills you. Couple hundred here, couple hundred there, and before you know it your budget is out the window. IF you find a donar car, and can get it for around $4500....then you are in there. I have seen donar cars go cheaper than that...but not often. If they are, they are usually so bad you cant get everything you need.
Good luck though! Keep us posted with what you decide to do!
Justin
