ls6 into 2000 camaro help
Old Nov 14, 2006 | 11:14 PM
afmoose7's Avatar
Default ls6 into 2000 camaro help
i kno this has probually been covered, or is just really simple, but i have searched and found nothing...i was wondering was all it takes to drop in a corvette z06 engine (ls6) with the tranny into a 2000 v6 camar0...is it just pull and place? are the wiring harnesses similar so the vette engine will wire up...any special things i will need such as bigger radiator (i kno i will need this)
any help or link appreciated.
Old Nov 15, 2006 | 03:37 AM
Cop Car's Avatar
you need all the computer harness associated with the donor V8.
you *may* need to replace the fuel pump, but the tanks are the same
i think you will have to replace the fuel lines
motor and transmission mounts need to be changed
in reality it is not that difficult, V6s have the same suspension and brakes as Z28s, only real diffrence is the motor
i belive the radiators are the same also
Old Nov 15, 2006 | 07:40 PM
afmoose7's Avatar
so where can i get the mounts, and does will i need to purchase a WHOLE engine harness, im going to buy a swap with a harness if i can but it will most likely be cut, so will it wire to the v6 harness or will i need to pull the v6 harness and wire it all up with the vette harness?
Old Nov 15, 2006 | 09:16 PM
Cop Car's Avatar
pull complete harness with V6, buy a complete LS1/6 with harness. for motormouts best bet is in the for sale section here.
Old Nov 16, 2006 | 09:29 AM
Scooter70's Avatar
You're going to have to put the F-body V8 oil pan and pickup on the LS6 as well. The Corvette pan won't work.
Old Nov 16, 2006 | 11:12 AM
ghettocruiser's Avatar
Dont forget you'll have to ditch the rest of the vette drivetrain and get an f-body transmission
J.
Old Nov 16, 2006 | 02:28 PM
afmoose7's Avatar
what do you mean teh rest of the vette drivetrain? im just gettin teh ls6 and t56 tranny
Old Nov 16, 2006 | 02:45 PM
1fine69's Avatar
Zo6's have a long transmission that runs to the rear diff...you need a standard-T56...your best bet would be to get a 2000-up Camaro LS1, and then if you really want it to be a Zo6, swap over the heads/cam....or just put a better heads/cam combo in it to make more power than a stock zo6.
Old Nov 16, 2006 | 03:40 PM
LS1Aggie09's Avatar
what fine 69 said...and then reap the insurance benefits of having a "V6 camaro" on paper. You should highly consider doin a cam/head swap on a 01-02 LS1 (since it will have the LS6 intake manifold already) while the motor is out of the car and before you put it in.
Old Nov 16, 2006 | 03:48 PM
afmoose7's Avatar
hate to ask such easy questions but approx how much does a head/cam package cost...i could get labor for free or cheap so im not worried about that and i wouldnt wanan do actualy machine head work bc i kno that costs big, so how much would the upgraded heads and cam costs....i wanan try and keep the swap under 4500.00...is that too unrealistic?
Old Nov 16, 2006 | 04:59 PM
Cop Car's Avatar
with a budget of $4500 you should start looking into automatic swaps and also the truck 6.0 and 5.3 motors.
Old Nov 16, 2006 | 08:46 PM
afmoose7's Avatar
well id rather not do auto or the truck swap...ive located both an ls6 and ls1 swap with t56 tranny around my arear for 4500 and i plan on speding A LITTLE extra on little things...can it still not be done?
Old Nov 16, 2006 | 09:03 PM
glock73110's Avatar
NO not very likely
Old Nov 16, 2006 | 09:36 PM
BrandonDrecksage's Avatar
the ntus and bolts of the swap(read: ecu, wiring harness, clutch, mounts, rear(v6s for the most part came non posi, select few did)...ect) start to add up. Why not jsut buy an ls1 fbody in the first place? The nickel and diming will kill ya. On top of that, if your paying someone to do this it'll cost a boat load. If you do this, it'll drive you crazy. Imagine trying to track down electrical problems with half a v6 harness and have a z28 harness. more trouble than its work.
Old Nov 16, 2006 | 09:51 PM
afmoose7's Avatar
well the reason is cuz i got a 2000 v6 camaro for 2900 bucks...and i want more out of it, and i know a swap is possible, and its not that difficult, and i have alot of friends with good knowledge on this sort of thing and would help, but this forum is helping alot though, i might need to reconsider a budget, but still what do you guys think it would cost, i wish i knew someone who has done it, how do i find out if my tranny has a POSI, its a 5spd but i dont think that makes a differance does it?
i will need:
engine
tranny
mounts
ECU
harness
fuel lines
rear end (possibly)
anything else?
Old Nov 16, 2006 | 10:19 PM
i will need:
engine
tranny
mounts
ECU
harness
fuel lines
rear end (possibly)
anything else?
by your response of asking if the tranny is posi..I don't think you shoudl attempt this at all. The rear si what comes with posi. also, the t56 isn't a 5speed, its a 6speed. why not look into a turbo kit? hey make them for the v6 and its probably a lot less complicated than this swap. Like you said, this swap isn't hard, its just really time consuming and detail intensive. If you screw up one connector, your gonna have a hard time finding it. On top of that, why not just swap the ls1 int a completely different car liek a 240sx or rx7. you'd have a lot less work to do and a lot mroe people have done it.
Old Nov 16, 2006 | 10:28 PM
afmoose7's Avatar
im sorry i did mean rear end and i kno the t56 is a 6 spd. those are just typos, and im really not doing the work, i know a few guys that are capable of doing the swap, but i need to get the stuff first, i just really want a v8 in there, i thought about a turbo kit but they are waay too expensive and its not worth it makin the stock power of an ls1(until you go internal engine parts and crank the boost) the truth is i just got into domestic, i had a honda civic in which i swapped in a b18c1 and boosted
Old Nov 16, 2006 | 11:27 PM
01WS6/tamu's Avatar
rack&Pinion, refrigeration lines, radiator, hoses, v8 kmember dead correct harness for a 2000 unless you mind a little tinkering with a few connections, Exhaust manifolds, headers, y pipe,catback,clutch ,slave, master cylinder, pedal asm, custom tune, all front accessories and f-body brackets, Shifter asm either auto or stick, lots of moneey & patience.
Old Nov 17, 2006 | 12:17 AM
MOLESTER's Avatar
in my oppinion if you really wanna do the swap and still save money is to buy a whole ls1 f-body that is totaled from water damage or has frame damage, you'll have every thing you need and whatever is left you can part out and make some money back. you should be able to find a whole totaled f-body for around 3000 (just guessing but im not really sure)
Old Nov 17, 2006 | 12:42 AM
fast01's Avatar
+1 for a turbo kit. The 3.8 that comes in these cars is essentially the same as the Grand National and we all know how they run.
