My LS1 RX7 Build
went a little to hot into the shutdown area that had some gravel in it.
more pics here
http://s61.photobucket.com/albums/h44/Sabre002/
100_0508.flv - Video - Photobucket - Video and Image Hosting
Made 392HP / 361TQ on a mustang dyno and it was hot a humid out too.
Here is another pull I dont know what was up with this one but the load on the dyno does not seem to be right at the top end.
100_0509.flv - Video - Photobucket - Video and Image Hosting
The guy was having trouble with my clutch it was kinda funny.
I'm thinking of using both of them for the track I think it will work well even though it is over kill from what I have read. I still think it will work well with the built in stats just would like to know what they open at.
Also would it be needed to do anything to the oil pump to get it to push all this oil through this setup? My pump has already been ported do I need to shim it to up the pressure any?
-Did you verify the thermostats open @ xxx temp (180*F or what?)?
-Any more info on modifying/shimming the oil pump to maintain proper pressure/function?
-Any oil temperature data from having the duals on the track?
-Where do you measure oil temps?
I sent you a PM on the "other" forum BTW. Sweet car man, love the sleeper look. BTW, update your sig, the v8rx7forum is no more
Yes they start to open at 160 and are full open by 180. I shimmed the pump .015 that was good for about 12psi
http://cgi.ebay.com/ebaymotors/New-W...Q5fAccessories
