My LS1 RX7 Build
Ebay
www.rx7club.com
www.v8rx7forum.com
just about any Rotary site.
Ebay
www.rx7club.com
www.v8rx7forum.com
Thanks for the info.
I'm thinking of using both of them for the track I think it will work well even though it is over kill from what I have read. I still think it will work well with the built in stats just would like to know what they open at.
Also would it be needed to do anything to the oil pump to get it to push all this oil through this setup? My pump has already been ported do I need to shim it to up the pressure any?
I'm just waiting for a friend of mine to get here with the GM weather pack kit so we can take apart the GM connectors to wire it in rather then cutting wires.
Now here is the oil cooler install. I used the OEM drivers side cooler with the Lingifelfter plate. the line is earls ultra lite 350 -10. on the plate there is a 120 deg and a 90 deg. In the cooler it is Setrab oil cooler fitting works great, I just need to take back my two fittings for the line on the cooler side I relized that a strait fitting will work better then the 90's I got.
It also cleared the headers (JTR 1 7/8) but I had to make me a secial tool get the oil cooler adapter tight.
Steven
401,
The car is going to be a little bit of everything my friends call it the track car with AC.
Here is a pic I took on the road yesterday lol
Then the new Bosch 044 pump
Just adding a long needed update to my build thread.
I had some trouble with fuel pressure dropping off so this is what I did to fix it.
Now the fuel pressure barley twitches one PSI on a WOT pull. I cant wait to get it back to you guys to finish the tune. I also had some crap in the filter I think that was a good bit of the trouble there. Along with some on the pick up screen on the old walbro pump.
