My LS1 RX7 Build
Old Nov 21, 2006 | 11:35 AM
Sabre002's Avatar
Originally Posted by Mas280
Sabre002 Your build up looks good. It looks like you are using stock heads. Do you plan to run 10's on the motor or with NOS? There have only been 2 RX7's too run 10's NA with a stock short block with ported heads.
Oh I plan on getting into the 10's with the bottle, I think I should be able to do it with a 150 shot
Old Nov 21, 2006 | 08:45 PM
Sabre002's Avatar
Thanks for the kind words guys. Yea the bead blaster is like a drug once you start its hard to stop.
Old Nov 22, 2006 | 08:58 AM
ghettocruiser's Avatar
Were you taking your parts somewhere to bead blast them? Or do you have your own? If you have your own...whats your set up? Ive been wanting one of those for a long time now. Because, lets face it, the worst part to working on a car is cleaning the old parts. haha. I hate it. Sometimes, if the part is nasty enough, Ill just get another one thats cleaner. Thats now much I hate rust/grime removal.
Car is looknig great by the way! That is gonna be one fun ride when youre done! Make sure someone has a camera on your face the first time you really get into it on the road...the expression is priceless!
Justin
Old Nov 22, 2006 | 10:51 AM
Sabre002's Avatar
Item # 39170 Steel Blater Cabnet Floor model
that's what it says on the front at least
What is better is the big *** compressor that runs it.
I'm using a glass bead for the compound.
Old Nov 22, 2006 | 12:10 PM
Nice...thanks. Looks like maybe a harbor freight part number??? They have some, but Im always skeptical about them. I might have to check one of them out... Just wish I could get the bigger parts in one of those too...
Justin
Old Nov 22, 2006 | 12:18 PM
Finite1's Avatar
interesting.
subscribing.
Old Nov 22, 2006 | 04:06 PM
Sabre002's Avatar
Justin
yea its a harbor freight one. I got my 16" rims in that one and the rear drive axels I have had some big parts in there.
Old Nov 24, 2006 | 10:42 PM
Sabre002's Avatar
Alright here guys here are some update pics tell me if you can tell a difference haha. I have done some cleaning and a little painting. I moved some wiring harness and tied them back up where they need to be. Does not look like much but its the detail that counts.
Here is where I'm going to be moving the fuse boxes to. I'm test fiting the bracket right now and seeing how it is going to fit.
here is behind the fender I just cleaned.
I just cleaned and painted the cowl peice.
Old Nov 26, 2006 | 01:21 PM
2MCHPWR's Avatar
lookin good dude. so after you bead blast the aluminum suspension pieces, do you spray it with clear or something?
Old Nov 26, 2006 | 03:01 PM
Sabre002's Avatar
Oh yes everything Aluminum got clear coat.
Old Nov 26, 2006 | 05:05 PM
2MCHPWR's Avatar
what shox and springs are you gonna use? while no bumper, swap out the horn with autozone one
Old Nov 26, 2006 | 08:09 PM
  #32
Sabre002's Avatar
I have not got that far as of yet. The money has been going else ware to mod the motor and get this damn thing on the road. I was thinking getting some H&R springs with some Koni's for a cheap start until I get some coil overs. What would you suggest?
Old Nov 27, 2006 | 09:52 AM
  #33
2MCHPWR's Avatar
koni's with ground control coilover conversion is good and will give you infinite choice of spring rates, and give you more clearance to run bigger wheels up front. also tein flex is good coilover.
Old Nov 27, 2006 | 11:47 AM
  #34
Sabre002's Avatar
You would not have a link for that Koni setup would you? I dont know if I have seen that setup.
Old Nov 27, 2006 | 05:54 PM
  #35
2MCHPWR's Avatar
call sam strano first:
http://www.stranoparts.com/index.php
but for reference from shox.com:
012. Koni sport shocks 1993 - 1996 Extenally adjustable shocks, price is for a set of 4. Shipping is free. $616.00
050. Ground Control Coil-Over Kit 1993 - 1996 Kit cotains Eibach ERS springs and mounts, no shocks. Lowers car 0-2 inches. $599.00
tri point is another good rx7 shop that deals with suspension:
http://www.tripointengineering.com/i...17adf3c3630407
Old Nov 28, 2006 | 09:37 PM
  #36
Sabre002's Avatar
Here is just a little update from what my father worked on today. Did a little body pannel alignment I'm sure that was fun I'm almost glad I was not there lol.
Old Nov 29, 2006 | 11:47 PM
  #37
RollinSScamaro's Avatar
i'm subscribing to this for when i do my build.. hopefully within the next year or 2 haha.. great job! i'll keep an eye on this thread!
Old Nov 30, 2006 | 09:20 AM
  #38
OJmobileII's Avatar
did u blast them before powdercoating? if so, any pics or description of how they turned out?
Old Nov 30, 2006 | 06:03 PM
  #39
TonyG's Avatar
Just picked up my roller, going to get my motor this weekend...and now found someone with the same goals, and beautiful work....merry xmas to me.
Keep up your good work!
Old Nov 30, 2006 | 08:08 PM
  #40
Sabre002's Avatar
I have not powdercoated anything. I have just beadblasted ad painted everything.
