Carbed LS1 guys please HELP
Old Nov 17, 2006 | 02:02 PM
caged02's Avatar
Default Carbed LS1 guys please HELP
I am having a hard time getting my LS1 to idle right. I am running a 232/236 .595/.601 lift cam with a Victor Jr. intake and a 750 mechanical secondary Speed Demon carb with a auto. I am running the #6 chip in the box for the timing. It either idles to high (1200 rpm) or if we get it anything under that the idle is kind of all over the place. It almost sounds like a timing issue rather than dialing the carb in? Please help if anybody else has this same kind of set up or have experienced this problem.
Thank you,
Scott
Old Nov 17, 2006 | 04:38 PM
chevydad's Avatar
did you set the idle mixture screws?some of the demons had a idle adjustment in the center of the carb where the aircleaner stud would go.
possible air leak?
Old Nov 17, 2006 | 05:24 PM
Vcious04's Avatar
More that likely it's the idle mixture screw's. I always turn them all the way in, and them back both the front 2 out 1.5 turns each. If yours has rear idle mixture screws, turn them all the way in (off), no adjustment.
Also, turn your fuel pump on only and check your float levels. Very critical..
I have never used speed demon carbs before so this might not help very much. I am VERY familiar with 4150 style holley's..
Old Nov 17, 2006 | 07:42 PM
PRAY HRD's Avatar
ok, first of all, your sig says you're running a speed demon carb on you mustang. i'm just making sure i'm not missing something here.
second, have you posted pics of you conversion yet because if you haven't, shame on you! i'll try doing a search for it now, but i'd love to see & hear more about it. feel free to shoot me a pm too please.
-Dave-
Old Nov 17, 2006 | 09:49 PM
LQ4Monte's Avatar
Sounds like a good old vaccum leak to me. Spray carb cleaner around the base gasket with engine running or stick you hand over the carb (watch out for carb backfires if you do this) and manually choke the carb. As Vcious04 said return every thing to default to make it easier to get the engine running. A vaccum gauge is a handy tool when tuning a carb. Hook it up to a port and check vaccum reading.
Another thought it could be you are idling on the primaries and when you bring the idle down you go dead rich or lean and the engine dies. If you have a manual for the crb read it twice. If nothing else give demon's tech line a call or email them.
If I remember right the newer speed demons have idle ease which allows additional air flow in the idle circuit. Just like when the old boys drilled the throttle blades on holley's to get rid of off idle stumbles.
BTW it is always a good thing to have extra carbs sitting around if you are having issues. I had/have an old carter AFB that I have used as a baseline carb when I couldn't figure out what was going on with a car.
Old Nov 18, 2006 | 10:03 AM
caged02's Avatar
Thanks everybody for the advice, I pulled out the plugs and they were black. We jetted the carb down and cleaned up the plugs and that helped alot. I was running a #6 pill and I think that was a lot of my problem. I talked with TJ on here and he said he has the best luck with the #1 pill. So I am going to try that and see what happens.
Old Nov 18, 2006 | 12:19 PM
Vcious04's Avatar
-Dave-
Dave, thats funny, I did not relize I still had that in my sig. I was going to try a speed demon but relized it was built differently than a 4150 style carb.
I am on dialup and sending pics takes forever. But I am at work now and can send you some pics through email and you can host them for me. Thanks man.
Old Nov 18, 2006 | 03:10 PM
PRAY HRD's Avatar
oh, ok. and i'll assume you meant to say IF i'll host them for you, which i would do no problem. it's not my bandwidth so i don't care! if you send an e'mail, you must put down DAVE in the subject to i can find it really easy and moreso that my wife will see my name and not toss it out.
later.
