Oil level sensor question
Old Nov 21, 2006 | 03:06 PM
Indyjc's Avatar
Default Oil level sensor question
If the sensor is not needed are you guys leaving the sensor in or are you welding up the hole. Taking the pan in to next week to be notched. Thanks John
Old Nov 21, 2006 | 03:22 PM
stealth71's Avatar
Can do either of those or just plug it w/ a threaded plug. Some have used this hole for oil temp sensors, so I wouldn't weld it shut unless necessary. You might want it down the road for something.
Old Nov 21, 2006 | 03:29 PM
bczee's Avatar
You can get a Help or Doman oil plug that is 20mm x 1.5mm to plug it
Old Nov 21, 2006 | 04:22 PM
Indyjc's Avatar
Thanks for the info, looks like the best route is to put a threaded plug in. Thanks
Old Nov 22, 2006 | 09:10 AM
ghettocruiser's Avatar
Or just leave it... I left mine, with the thought taht some day I might hook it up to one of my dash warning LEDs...
My main thought was...the cast oil pan. God forbid, if I bottomed out on something and it cracked open. That light would come on, and I could shut it down before I go barreling down the road with a dry block. With a regular steel pan, you get a dent...
Not saying its probable...but thats just what my thought was on it.
Justin
