More 240SX Clutch Master Questions...
#81
haha it was worth a shot
no big deal, ordered the mcleod adapter, -4 female to -3 male adapter, 36" -3 to 10mm banjo line, then the banjo bolt. an extra $20 is a drop in the bucket at this point haha.
also ordered a set of headers that might not require modification, but ill reveal that later
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#82
also ordered a set of headers that might not require modification, but ill reveal that later![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#84
eh was worth a shot lol
why didnt they work?
You may get lucky and they will work since you might have the engine in a different spot. I hope for you that they will work for they are cheap headers and if you could get them to work that would be great! I ended up buying a cheap set of long tube headers and some bending mistakes and I'm going to eventually fab up my own set of long tubes. They won't be pretty but they should work is how I'm looking at them!
#86
Originally Posted by cnichols
Best to just order the Hinsons. I fabbed everything else, but the quality of their headers is well worth the money...especially considering the time saved.
#87
....You have to remove the tension pin first and it comes right out. *NOTE: The Russell package comes with two. One did NOT fit. Not sure if they were supposed to be identical or not, but there was a slight difference between the two. One fit pefect, the other would not go in.....
#88
Find a small punch and tap it out using a hammer. Once you have enough sticking out of the other side to grab it with some dikes or pliers, do so. Sometimes twisting while pulling helps.
Or go to your local cheap hardware store like Harbor Freight and pick up a tension pin remover for $15-25.
#89
My neighbor got it out for me he just used a small punch and gave it a few good wacks with a hammer. Worked great and then just hammer it back in once you put the other adaptor in.
