Fuel Pressure Regulator help....
Thanks in advance.
After that, all the fuel rails are "deadhead", they only have one line going to them. This includes the Z28 rails, and all the truck rails.
The 'vette filter regulator is a pretty simple, cheap, easy piece. It has 3 ports, fuel in (3/8"), fuel out to engine (3/8"), and fuel return to tank (5/16"). Its inexpensive ($40 or so at most any parts store) and provides the correct pressure (about 58psi, assuming your pump is up to the task).
You certainly can spend more on a filter/regulator setup, but this is adequate for most setups in the 400hp range. Not sure what the top limit is. If you're going big (high hp or Nitrous) you might need something with higher flow capacity, but then you're probably also going to need aftermarket rails, bigger fuel lines, bigger pump(s), etc.
'JustDreamin'
Thanks in advance.
the next mini hurdle will be matching up line size and fitting. yours will be easy compared to mine.
Here is the setup...
http://www.bbfhp.com/BurtSpecsLS2Sig.html
