PS Thread Pitch
Old Dec 16, 2006 | 10:27 AM
datboibrad's Avatar
Default PS Thread Pitch
anyone have a clue what size fittings will fit the power steering pump/resivor. going stainless lines to a front mounted cooler.
Old Dec 16, 2006 | 10:39 AM
icantdrift's Avatar
the cooler goes on the return side so all you need is hose and clamps.
i have no clue what fitting the pump uses for the pressure side. i used the stock line with compression fittings to adapt to the stock 240 line.
Old Dec 26, 2006 | 09:46 AM
datboibrad's Avatar
thanks :]
Old Dec 26, 2006 | 09:53 AM
cnichols's Avatar
I think it's 16mm x 1.5
Old Dec 26, 2006 | 09:57 AM
datboibrad's Avatar
well i found on on the 240 end of things.
PS line into PS rack have two different thread pitches.
Bigger one is return line. 16mm x 1.5
Smaller is in-line. 14mm x 1.5
Old Dec 26, 2006 | 10:28 AM
cnichols's Avatar
So, for clarification...
LS1 Pump (hi-pressure) 16mm x 1.5 ---> 240 rack (hi) 14mm x 1.5
LS1 Pump (low) 3/8" nipple ---> 240 rack (low) 3/8" nipple to 16mm x 1.5 (adapter already there from the factory)
