Zo6 wheels on 71 Chevelle
Old Dec 17, 2006 | 11:28 AM
grafking's Avatar
Default Zo6 wheels on 71 Chevelle
I have a 71 Chevelle it has stock axel and rear. I was wondering if Z06 wheels and tires would fit on the car withoutu any problems..
thanks
Old Dec 17, 2006 | 01:14 PM
datboibrad's Avatar
wrong forum...
Old Dec 17, 2006 | 01:34 PM
bczee's Avatar
No.. the bolt pattern is different and the offset is incorrect, as far as the stock wheels..
You can get a adapter to handle the bolt pattern 5x5 vs 5x4.75 and the offset. I am not sure of the Z06 wheels offset.. but I am sure it is not that hard to find out and with the correct adapter you can get them mounted..
Next question would be is.. do you have enough room for them..
Good luck
Old Dec 17, 2006 | 01:37 PM
jfman's Avatar
I think covette wheels have WAY more offset that Chevelles. They will look tucked in.
Old Dec 17, 2006 | 03:40 PM
ls1_chevelle's Avatar
Look in my sig. I'm doing it currently. You will need roughly 2" ADAPTERS all the way around. Look at spending no less then 250US for lug-centric adapters. Hub-centric is better and will cost you 25 US extra a piece from what every shop has told me(internet and locally).
-Matt
