Ls6 Engine Kit For 01 Z28
Old Dec 25, 2006 | 04:53 PM
STEALTH01's Avatar
Question Ls6 Engine Kit For 01 Z28
Ok i have a guy selling me a LONG BLOCK C6 ENGINE WITH 0MILES STILL IN CRATE for 5,000 im going to buy it if the alt,powersteraring,and all other accesories bolt right up will they or will i have problems adapting it to my z28 ?
the balencer and flywheel will that fit of my Z on the c6 engine ?
Old Dec 25, 2006 | 05:43 PM
nycab's Avatar
what exactly are you trying to ask? the ls6 and ls1 blocks are basically the same. you may have to drill and tap some holes for the accessories, but they will all fit in. $5000 seems like a hell of a lot of money to spend on a ls6 tho.
Old Dec 25, 2006 | 08:16 PM
Stu Cool's Avatar
LS6 and LS1 blocks are the same externally, In fact you might even have one in your '01, I know some '02s did.(Blocks that is, not the LS6 internals) Everything should bolt up.
You can buy an LS6 Service crate engine for 5289, with a Camaro pan from SPDC and others. $5000 is not much of a deal, unless he can transfer the warranty to you as well.
http://www.sdpc2000.com/catalog/120/...il-Pan-Kit.htm
http://www.crateenginedepot.com/LS6-...8399-P9C2.aspx
Pat
Old Dec 29, 2006 | 06:53 PM
IOwnCalculus's Avatar
Is it a LS6, or is it from a C6? C6's have the LS2, not the LS6.
Old Dec 29, 2006 | 10:10 PM
BrandonDrecksage's Avatar
exactly what I was going to type. Not to mention you can get a built bottom end for cheaper and you woudl have to worry about yuor stuff bolting up to a ls2.
Old Dec 30, 2006 | 09:42 AM
nycab's Avatar
whoa i totally misread (saw C6, read LS6). for an ls2, i *think* all accessories will bolt up. the price becomes better, too .
edit: actually, i read both, looking at the title again...
Old Dec 30, 2006 | 12:13 PM
Scooter70's Avatar
I can change the thread title when STEALTH01 comes back and confirms what it is that he wants to do. Is it an LS2 from a C6 or an LS6 from an '01-04 C5 Z06?
