LSX into LT1
This is my idea. I am looking into building up a LSX 6.0l iron block out of a truck. I have a 95 Z28 LT1 OBDI car, LT1 PCM, etc. I can get a LSX PCM, Harness, and build the Engine up.
This is the problem:
I want to find a Harness, or build one that will run the Engine and Transmisson, connect to the PCM, and adapt to the 3 plugs underneath the dash so the guages will work. I know it will be primarily a LSX Harness, but it still has to connect to the dash.
Does anyone know who can do this, or have any wiring diagrams that I can follow to build it?
Would it be easier to get a complete LS1 Dash out of an F-body Car, wire that in and use that?
You could also do it yourself, I don`t know of any wiring diagrams for a LSx into a LT1 car though, LS1 into a v6 I know of
but I don`t think that would be as much help. If you get full diagrams for the car and the LS1 it wouldn`t be too hard.You could use the LS1 dash and harness, but for that to be a direct plug in I would think that you would end up changing a lot of wiring in the car.
there are a few wires on the ls1 harness that are originally going under the hood but need to go back to unnder the dash on a LT car.
FAQ and www.shbox.com is your friend.
I can get Pin Diagrams and figure out what they all go to, then go from there I guess.
https://ls1tech.com/forums/showpost....50&postcount=8
-Just called them, and they do offer it for a good price. Looks like a few people are starting to do that now..
