Drive by wire + 98 harness
Old Dec 30, 2006 | 03:27 PM
digitalsolo's Avatar
Default Drive by wire + 98 harness
Hey guys,
Does anyone know if it's possible to actuate a DBW pedal with a 98 PCM/Harness (obviously with the addition of the TAC module and necessary pedal)? It's that or a Holley/NW T/B for my L76 intake, and the DBW setup is quite a bit cheaper, if a little more technically complicated.
Thanks-
Old Dec 30, 2006 | 10:38 PM
G-Body's Avatar
sawzall wielding director
That sounds like a can o worms.
I`ve never tried it, but my guess is that you would need to update to a 99+ computer in order to control the DBW. Updating to a 99+ computer with a 98 harness means repinning like all but 5 of the wires on the PCM connectors, plus you would still have to add in the wires for the DBW pedal and TAC.
Its not that it couldn`t be done, I`m sure you could do it, but I think it would be a lot of work.
Old Dec 31, 2006 | 11:48 AM
Gotcha.
I didn't know if the DBW was a seperate circuit with a controller. i.e. a cable from the throttle to a box, that also plugged into IAC/TPS. Sounds like it's fully integrated into the PCM. Screw that, I'll buy a Holley, it has more hood clearance anyway.
Thanks-
Old Jan 1, 2007 | 04:23 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
The 97-98 PCM does NOT work well with the electronic throttle in a swap! You want 99 and up for ETC.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
