Took it for a ride
Old Dec 28, 2006 | 03:16 PM
pt67camarols1's Avatar
Default Took it for a ride
Today was a nice day and took the camaro out for a ride and after couple of miles LS1 start studdering and came to a stop. no start. It was fine whole summer and I did not drove the car in a couple of months. This morning battery was low and I had to gave a jump start but I connect the battery on the wrong posts got a litkle spark and correct it . It started fine and died on me on the road. What could that bee? Any Ideas? Thanks
Old Dec 28, 2006 | 06:09 PM
rocketrider93's Avatar
alternator/ battery maybe. sounds like when the alternator was going out in my truck. it ran everything for a few miles but the fuel injection and everything sucks the power out of the battery pretty quickly if it is not being charged. i would check the alternator and go from there. when you tried to restart it was it cranking over and everything and just no fire?
Old Dec 28, 2006 | 07:30 PM
Yes it was crancing till the battery died. But when it started running crapy voltmeter was reading almost 14 volt.
Old Dec 28, 2006 | 10:21 PM
patriotformula's Avatar
huh... that sucks, if it wasnt at 14 i could understand it. FI gets pissed when its not running at optimal voltage.
Old Dec 29, 2006 | 12:00 AM
PRAY HRD's Avatar
have you checked your main grounds?
Old Dec 29, 2006 | 01:53 PM
I will check the grounds but I dont think thats the problem. Does fuel pump still humm even it is bad? Thats another suspicious think that I have to check.
Old Dec 29, 2006 | 02:05 PM
PRAY HRD's Avatar
guy i work with just had to get a new pump in his van. i didn't think it was the problem since we could here it hum, but after towing it to a dealer, sure enough, it was bad. replaced it and it started right up. could be a possibility. although, if your ground was bad, you probably wouldn't be getting current to flow through it, hence it wouldn't hum at all. hope you figure it out though. sucks figuring elec problems out, that's one reason why i'm converting to carb by spring! lol.
Old Dec 29, 2006 | 02:41 PM
ghettocruiser's Avatar
You can check for fuel pressure at the rail. You can see if you get a good spray out of the shrader valve, covered with a towel... Or you can rent a fuel pressure gauge from autozone to check for correct pressure.
Even tho your gauge showed 14volts, Ide still be blaming the charging system. There is a single, small gauge wire that comes from the PCM and tells the Alt. to charge. Its fragile, and prone to burning. Mine would go off and on. Sometimes it would charge fine...sometimes the gauge would show 11volts until I wiggled that wire. As mentioned above it doesnt take much to drain the battery if the alt isnt up to snuff.
Also, Ide be a little worried since you hooked the battery up backwards... You should check all your fuses, and all your grounds, and everythign you can think of. If there isan autozone near you...take your alt off and get it tested. Its free and you can pretty much rule that out.
Let us know what you find!
Justin
Old Dec 30, 2006 | 02:05 PM
I'm suspicious about fuel pump too. About connecting the battery wrong; if that was the problem I dont think it would start. Well I wiil plat with it tomorrow and see whats wrong.
Thanks for all the suggestions and help guys.
Old Dec 31, 2006 | 11:41 AM
Today I tested the fuel pressure on the rail while priming / cranking the engine and 0 pressure. That's sure is a fuel pump problem right? Pump is priming but no pressure. I will take it out and test it again to see what is the problem.
Old Jan 1, 2007 | 01:38 AM
red90cobra's Avatar
yes if your not getting any pressure while cranking and the pump is suppose to be on
Old Jan 1, 2007 | 10:12 AM
PRAY HRD's Avatar
ok, here's one more option. i had this problem with mine where it would crank & crank, but it would not fire & no reading on the fuel press gauge. i have 2 relays supplying power to the pcm. hold 1 in each hand and have someone crank the motor. when i did it, one clicked and the other did not, so i swapped the relays with the plugs and had him crank it again. this time the same relay clicked in the opposite plug and the one that did not click the first time, still didn't in the opposite plug. a quick trip to Autozone & $15.28 later, pluged the new one in, in place of the one not clicking, and boom it fired right up.
good luck.
Old Jan 1, 2007 | 01:17 PM
good luck.
How would you explain to me , no pressure on the pump and bad relay for the pcm. Did I miis something here? Pls explain
Old Jan 1, 2007 | 02:13 PM
icantdrift's Avatar
the pcm activates the relay for the pump, at least that's the proper way to wire it. when you click the key on it should prime, then stop after a couple seconds. then when you begin to crank the pcm activates the pump again.
when you say the pump primes do you mean it builds pressure when it primes and the engine is not turning over? or do you just hear the pump click on a for a few seconds then off?
Old Jan 1, 2007 | 03:29 PM
Pump primes and engine turns over but no start. No pressure. Allso no pressure when it is priming when the key turned half way. I might have to check relay for the pump.
Old Jan 1, 2007 | 05:42 PM
icantdrift's Avatar
if you hear the pump run but have no pressure it's either a bad pump or bad pressure regulator (or leak but you'd know that already).
